I used mine to learn how to hover etc, and after many many hours it is now a flying wreck. Twitches and glitches like mad I don't think it's worth throwing any money at it when an Esky Lama3 can be got new for appx £50.
Steve webb sells just the frame etc (no TX) and includes 4 in 1
for the Bell
If it flies for a little while first & then stalls, it's either that there is so much resistance that a fully cahrged batt can overcome it for a while, or that the batts are knackered.
Does sound like the batts.
Happy Landings.
David
Raptor 50. OS50 Century Bell 47G in Yellow - Beautiful!
Mcpx
Blade 130x
Goblin 500
Go to your supplier and ask for a replacement, I've had serious issues with my BCX2 and Elite Models are sorting out a new Blade for me with there suppliers, and I've had mine since August last year.
Spoke to Rod today and he said it should be all sorted by next week.
This is where good customer support is worth paying for, not that they were more expensive then other suppliers, but why I never buy this stuff from Flea Bay
Latest Latest Update - I have now change both motors, both bearings (and refit with plenty of WD40), Inner and Outer shaft, bottom blade holders and guess what, still the same. I get around 10 seconds of what seems like normal flight and then it drops to the ground and stays just a few inches. I have noticed that every time I use the cyclic then moving the servos causes the power to drop even further. I have tgweaked with pots on the 4 in 1 but still the same.
Am I throwing good money after bad on this? I've only had it a few weeks!!
Is it the bin or a new 4 in 1?
Help...............
RichT
sigpicWayne AKA OB1
Blade CX2 / Trex 250SE / Trex 450 SE V1 / Trex 500esp / Trex 600 Nitro Pro / Raptor 30 V2 / DX6i / DX7 / Phoenix / Ripmax twin Dock PSU / Cellpro 10S & 4S / Imax B6 x2. Prankster Nitro / Delta Push Prop / Swift 2 Flying Wing x3 / Swift 2 (Night Flyer LED Lit) / Swift Maxi Wing / Squall 4S/ HZ Ember / Wot 4. (all 2.4ghz) Plus 3 Eddie Gold Stars, yay! Trex 450XL - Destroyed due to complete power failure at height.
