Totally give up :o(
    Originally posted by robgt View Post
    On my little indoor contra thingy (basically a walkera 5G6) - the top flybar affects the toilet-bowling effect, and general flight characteristics.
    If you flip it over and clip it on the other side, it might sort it?
    Get it on the wrong side and it's a pile of whippy dog doo...
    you can type quicker than I can
    TDR (in progress)
    SAB Goblin 700
    Vibe 90SG Vibe 500E
    Kalt Baron30
      I've spent too long using confusers
      | 3D Championship
        Please excuse me guys, I'll read and absorb all your posts tomorrow morning, and thank you for all your advise.
        I've just spent the last hour stripping her down, adjusting all the servo arms so the swash is dead straight, got Clare to check it too, as in her job she needs a good eye, all the linkage arms are text book as they should be, yet as soon as I take off shes leans to the right sideways and is way out of control
        I've done everything by the book I can't see it being a bent shaft prob as that usually caused severe wobbling, how she is tonight if I had enough room she'd do a lovely nose down sideways circle, it's almost like she's weighed down and thats causing it.
        Please if anyone has more to say please say it, as I'll be going through all your messages in the morning, and I thank you all for taking out time to help me.
        Bugger!
        sigpicWayne AKA OB1
        Plus 3 Eddie Gold Stars, yay!
          sorry i posted this in the wrong thread
          http://www.rcheliaddict.co.uk/editpo...&postid=124478
          sigpicWayne AKA OB1
            Bugger!
            hi cambs flyer now its not my place to tell ya wote to do as im new as well, and i dont have your heli its just a thought realy but if you check your shaft on a peace of glass its a good way to spot if its bent , when i set up my swash for level i use an allen key tied to the shaft with cable ties at midstike 0 degrees when you have done then you know its spot on hope this helps BTW disconect the motor
              i leveled my swashplate by firstly puting all controlls in a central possition
              then switching on the tranny then plugging in the batt. i then unscrewed the servo arms making sure not to move the servos i then lined up the swashplate and made sure it was 90 degrees from the shafts from all views then i put the arms back but if they didn't line up with the splien i adjusted the connector rods until it lined up with the splien as near as possible and that should eliminate it from the problem and that should let u concentrate on other issues hope this helps a bit lol
              brian
              Trex 550e dfc :-)
              t-rex 450s x2 /Raptor 50
              kyosho spree small plank
              bogey combat plank x2 woop
              http://www.cuffleymfc.co.uk
                I just want to say a massive thanks to everyone for there great advise, unfortunately no matter what I do to correct one thing it upsets another and so on.
                I've just bust my third upper blade this morning I'm well so ****ed off with the fu*king thing, I could just bin it right now, the swash is level and she goes backward while spinning right, so I move the arms half a turn up and then shes flying forward out of control.
                I adjust the P/pot to stop left yaw the she turns right and visa versa.
                This has well and truly beaten me now, and when you have her hovering to something near normal, (and this is the bitch) as soon as you cyclic any stick input she goes crazy, hence three broken blades, shit I haven't broken a blade in months before now, this is one sick little heli and taken on board what you guys have said she still isn't playing ball.
                If anyone has any more ideas I'm all ears, but I can honestly say I haven't a clue what will fix this, when I upgraded to the alloy parts last year and twisted the servo arms up a notch the balance the swash after that she flew like a dream, I'm doing the same now and it's like riding a wild horse.
                Poxy bloody thing.
                sigpicWayne AKA OB1
                  Did you try the flybar flip I suggested earlier?
                  | 3D Championship
                    Yes mate, I even put a new one on I had spare, I fear this problem is far worse than any fly bar interference bud'.
                    sigpicWayne AKA OB1
                    • #25
                      Damn...
                      Worth a shot
                      Dunno what to tell ya...
                      | 3D Championship
                      • #26
                        take it back to the shop and get a newbie!
                        Align TREX 600NSP - Stable baby mark 2
                        Park Zone Trojan T28
                        Spectrum DX7
                        -Wellington Model Flyers
                        -Kapiti Aero Club
                        New Zealand
                        • #27
                          I've just put the arms back in the first holes and shes not so responsive now which is only making it slightly more manageable, but no matter what she keeps leaning to the right side and when I trim the arerion to compensate it it goes bleeding crazy totally out of control.
                          I've now packed it in for the day, I rang Elite models and they said bring her in, I'm not sure what there do that I haven't but thats where I am now.
                          I now havent any spare lower blades until tomorrow so I can't risk another crash, and Pip said he'd have a look at her for me tomorrow when he brings the Trex's over for a fly around
                          I purchased her back in last August so I doubt very much there's replace it for a new one now.
                          sigpicWayne AKA OB1
                          • #28
                            I think I've got to accept the bloody things f**ked.
                            The top rotas when moved by hand have a little more click click resistance then the lower ones which hardly has any more alloy to plastic lower gear noise when turning by hand
                            sigpicWayne AKA OB1
                            • #29
                              no no no no...Buy another, wait a week, take the old one back, e-bay the new one
                              Spectrum DX7
                              -Kapiti Aero Club
                              New Zealand
                              • #30
                                I know it wont help mate but id go out to the shed sit it on a block of wood and hit it as hard as you can with the biggest and heaviest hammer you can find , then pour petrol on it and throw a match to it , whiles whispering under your breath like a nutter ( " take that you little F@@KER") . Sorry couldn't help my self mate . These things are very frustrating when it all goes pete tong on yah.
                                REGARDS JAMIE
                                Knight 50,50 hiper,hatori pipe,gy401+9254,ttcarbon blades futaba ff7fast 2.4 ghz set up with 3152 digi s all round and a rev loc 10
                                450 rex standard setup
                                Phoenix sim...
                                Plus two gliders and one pits special biplane
