MCPX BL - More Speed on Tail movement
  • MCPX BL - More Speed on Tail movement
    Hi, I was just wondering what I need to adjust in my DX9 to get the tail to move left/right faster, I've found that its abit sluggish for my liking with no expo on it at all.
    thanks,
    Sam
    Spektrum DX9
    Align T-Rex 500 Pro DFC
    (WIP)
    BLADE MCPX BL
    PHOENIX R/C V4
    I don't think you can change it. I guess that's the limitation of a fixed pitch motor driven tail.
    Sent from my iPad using Tapatalk
      Negative expo?
        Originally posted by Bee_random View Post
        Negative expo?
        Sam said no expo
        Goblin , 380 Carbon
        Oxy 4 - 360
        Oxy 4 - 325
        Oxy 3 - 250 , 3s
        Oxy 3 - 250 , 4s
        Oxy 3 - 280 , 3s
        Oxy 2 - 190
        Oxy 2 - 210
        Spektrum DX9
        Revolectrix PL6 & PL8
          Kenny, if there's no expo then negative expo should increase sensitivity thereby making movements faster. Positive expo dulls down sensitivity on spektrum radios. I don't know if negative expo is available on spektrum radios as I've never done it.
          [/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
            If you're looking for a faster pirouette rate you can up the rudder travel in the transmitter mate I like 120%
            DX8
            Phoenix
            RealFlight 7
            Mcpx BL
            Trex 550 DFC with Vx1n
            Trex 700 DFC Pro Hv with Vx1n
            Zmr250 mini H Quad racer
              Of course you can change it!!! Just up your rudder rates in your tx. Rates or travel adjust. I have my nano at 115 on the rudder
              Stainburn Helicopter Club
              Sab Goblin Black Nitro 650
              MSH Protos 380
              Vbar Control
                Thanks everyone for your replies. I think I'll go with increasing the Travel and maybe dial in abit of negative expo see how that feels. Its just that I was out at the field today flying in 20km/h winds, in IU I found the tail abit laggy in circuits and not turning quick enough...
                Spektrum DX9
                (WIP)
                BLADE MCPX BL
                PHOENIX R/C V4
                  I would think the tail would struggle in those kind of winds anyway though. See how it feels with increased travel. I think there will be a cut off level wind wise beyond which the tail will struggle regardless of what you do
                  MSH Protos 380
                  Vbar Control
                    Spektrum radios do have negative expo and you can clearly feel it,
                    tough as mentioned here, increasing the travel to max, and then play with the D/R works well for the pyro rate in these micros.
                    Lann-ding...
                    Goblin 700/ Logo 700/600 /700X/ Synergy 516/ Diabolo 550
                    SouthHantsHelis
