beginner set up procidures in MHW mag
  • beginner set up procidures in MHW mag
    Just thought id say that the Model Helicopter World magazine has started fresh in the idle up section of full set up procidures on your helicopter . I found this very interesting reading while I was learning .
    REGARDS JAMIE
    Knight 50,50 hiper,hatori pipe,gy401+9254,ttcarbon blades futaba ff7fast 2.4 ghz set up with 3152 digi s all round and a rev loc 10
    450 rex standard setup
    Phoenix sim...
    Plus two gliders and one pits special biplane
    I read that as well. I presume all helis are set up according to the manufacturers spec. as it states in the mag that at mid throttle stick position you should have 5 degrees positive, my Blade 400 manual states at this position there should be 0 degrees ... Just a thought !!
      My mini titan manual suggests 0 degs at midstick also.
      Surely +5 degs that would mean the heli would try to lift off before it had enough power?
      JAMIE,
      -Mini Titan e325-
      Sonix cnc head & tail rotor
      GY401 & HDS 577 servo
      HS65mg's
      CY radix blades
      scorpion hk2221-8 motor & 55a esc
      Spektrum DX7-goodbye glitches
        You program the throttle curve in your transmitter accordingly to match the pitch curve.
        With the hover point set at mid stick and with the pitch curve set at -3 +5 +9 you will find it easier as a beginner to start the hovering practice as the stick movement is spread out more.
        Once you have gained the hand eye coordination and timing then move on to the 3D style pitch curve of -10 0 +10
        Member of Mk Heli Club
