Going up a Level
  • Going up a Level
    Hi all I am new to all this and at the moment I have a Esky Lama V4 which I am getting ok with and i was thinking of going up a notch and saw a Honey Bee King 2 Carbon ED for about £359 would like your opinion on it please.The spec is
    Charger and switching adapter• Height: 225mm • Main blade diameter: 600mm • Tail blade diameter: 130mm • Motor gear: 11T • Main drive gear:140T • Drive gear rate 11:140T • Weight 520g (with 1800mAh,11.1V)• Ener G LiPo Battery: 1550mAh,11.1V• Brushless 3900KV motor• Brushless ESC• Gyro: ESKY Pro gyro• Servo: 8g x 4Pcs• Transmitter: 6 channel 2.4G• Receiver: 6 channel 2.4GIncludes:• 6 Channel transmitter/receiver/gyro/servos• Carbon fibre main blades• Carbon fibre tail fins• CNC alloy rotor head set• CNC alloy full tail upgrade set• Painted glass fibre canopy • Brushless motor and speed controller Also comes with a head lock gyro and case and extra max force batt
    For that sort of money you are in Trex450 area and that would be by far the better heli, or a blade 400 that comes with a 2.4ghz radio for less than 300 quid.
    James
    Sponsored by
    Align-Trex.co.uk
    Optifuel/optipower
    MKS servotech
      blade 400 all up for less than that brand new and with 2.4ghz TX. Other than that maybe get a good second hand trex 450.
      Lee
      Lee
      www.raptoruas.co.uk
      www.lee.rcha-uk.com
      www.gensace.de
        Lee
        For the money you could buy a blade 400 and a few spare batteries, deffinately the best choice.
        James
        Sponsored by
        Align-Trex.co.uk
        Optifuel/optipower
        MKS servotech
          this might be a good idea - http://www.rcheliaddict.co.uk/classi...hp?product=688
          the belt cp is mint cuz it was mine only few days ago and i set it up.
          matty
          matty
          Spektrum DX7s
          DJI F450 naza/gps Trex 500
            You can get the trex 450 inc all the radio gear, etc brand new for less than that from trexmaad.co.uk
            Trex 450SE V1
            - Futaba 2.4GHz.
            Bladerunner Micro Mosquito - The toy.
            Pheonix -
            The less expensive way to crash.
              for less than £250? if so then i'll have 2 of em
              matty
              Spektrum DX7s
                Can you give us a link to that purchase please mate.
                All in this is what I found.
                http://trexmad.com/newstore/index.ph...02c80ba4402f50
                sigpicWayne AKA OB1
                Plus 3 Eddie Gold Stars, yay!
                  did you mean the £359 he stated at the start of the thread?
                  matty
                  Spektrum DX7s
                    OK, this deal blows the Blade 400 clean out of the water.
                    sigpicWayne AKA OB1
                      Great deal but I'd feel very brave if I was going to learn my first single blade flights on a Heli I built!
                      Otherwise if you want RTF I would stick with something cheap i.e. a base King II and you won't mind breaking it as much or the blade if you want the 2.4ghz. Even that is a complex rebuild after even the lightest crash!
                      Havin the heli sitting in front of you at take off rpm is a daunting prospect after a Lama, are you sure you are up to it?
                      I good sim might be the next step?
                      Esky Honey Bee King II DX6i
                      E-flight Blade 400 3D
                      www.danielantony.com
                        Rubbish!
                        I'd MUCH rather fly something I have built and not some overworked kid in a chinese sweat shop! Most if not ALL ARTF's should be checked over by a competent person before it's flown.
                        Building up the kit's also means you have some clue how to take it apart and replace bits when it crashes.
                        I'd agree a decent SIM is the best way to go though
                          Originally posted by Sao View Post
                          Rubbish!
                          You are more confident of your building skills than I was then!
                          I can't wait to build my own and you are right about the quality. But that is now based on my understanding what I own and the hobby. That wasn't the case at first for sure!
                            It's deffinately a case of horses for courses.
                            When I started there were no ARTF 'learner' helis I bought and built up my piccolo FP myself and back in those day's the usual responses were
                            'if you can't build and maintain it, you shouldn't be in the hobby'
                            but with the advent of ARTF's this attitutude is slowly changing and there are a lot more total newbies entering into the world of RCH's than there ever was.
                              Thanks for all the advice. I will start with abetter sim as i only have a esky at the moment. Sounds like the Trex and the Blade 400 are the way to go. Looks like there are some good deals out there. What about as Stringfellow suggest getting a basic king first. Maybe i will ask my girl friend and see what she has to say?
