Hummingbird tail motor problem
  • Hummingbird tail motor problem
    The small gear cog on my Hummingbird tail motor has dropped off!
    Do I need to replace the motor or can I just stick the cog back on? If the latter what's the best method.
    I take it we're talking about the brass motor pinion--
    If so it can be glued back on with Cyno/super glue if it's a good fit or with Epoxy if it's not..make sure all the old glue/oil/etc is well cleaned off.
    When using Cyno be carefull to only get the glue where you need it.
    Dave
