Trex 250 spools up while adjusting throttle trim lever (newbie)!!
This topic is closed.
  • Trex 250 spools up while adjusting throttle trim lever (newbie)!!
    While attempting to correct the throttle trim on my futaba t6 the heli spools up! Is this crazy or normal? Yes I'm a newbie and willing to learn so I'm all ears!
    1. Main blades are not connected to heli
    2. Throttle stick on transmitter is at zero
    3. 3gx mrs
    Firstly are u sure its the rudder trim and not throttle trim??
    2nd U shouldnt be adding trim to a tail mechanism anyway, the gyros dont like it
    3rd and not least watch some of the videos here on setting up helis ---->Heli Skills and Setup 101 - LOOK here first! - HeliFreak
    Collector of SAB Goblins
      My mistake I meant to say I was adjusting the channel 3 throttle trim lever. See video below
      https://www.youtube.com/watch?v=ndb7...077717]Firstly are u sure its the rudder trim and not throttle trim??
      3rd and not least watch some of the videos here on setting up helis ---->Heli Skills and Setup 101 - LOOK here first! - HeliFreak[/QUOTE]
        Start from the beginning. Why are you trying to add rudder trim? As Kev says, it really shouldn't be needed!
        I see your new to this game! Can I hazard a guess that when you try to hover, your heli drifts to the left!?
        Sent from my iPad using Tapatalk
          Yes im extremely new! My mistake I meant to say I was adjusting the channel 3 throttle trim lever. See video below
          Yes it does go to the left but I've read that this may be normal?
          20131126_185214.mp4 - YouTube
