Hex Drivers
  • Hex Drivers
    where can i get a high quality 1.5 Hex driver. Got a set of Thunder Tiger Hex and screwdrivers and the 1.5 has rounded slightly. I'am following Bob's videos building a T-Rex 500 and he says you need a 1.3 Hex driver for the set screw on the canopy mounting bolt. Where do you get this size from.
    loads of sites on google just search for 1.3 hex drivers
    Trex 550e dfc :-)
    t-rex 450s x2 /Raptor 50
    kyosho spree small plank
    bogey combat plank x2 woop
    http://www.cuffleymfc.co.uk
      hi Dave have you tried looking on www.midlandhelicopters.co.uk
      kasama srimok 90n
      T rex 700 Ys91sr futaba bls 452 GY520+bls 251 aerospire gov Fromeco reg
      Futaba 10c
      empty bank account
        i have the same problem as you with the 1.5 hex drivers...
        every single one i get snaps or rounds off...
        any one that can recomend one that wont break ???
          i also have the same problem with them rounding off
          i have a set of hudy drivers which are about £6-£8.00 each these done the same thing no impressed
          brought set of align one's no trouble with these but the handles are had to grip if the bolt is tight
          removed the shaft and fitted in to the hudy one's
          kasama srimok 90n
          Futaba 10c
          empty bank account
            Either a set of hudy as mentioned above (oh hang on didnt see you had issues with the hudy ones) I don know they do a few sets of tools some better than others, or some Losi drivers, expensive in the UK but if you order them from the Us it works out much cheaper.
              losi driver seem to be ok but all the ones i used arn't metric
              if you wont a bling set check out the kyosho one's in anice tool roll
              kasama srimok 90n
              Futaba 10c
              empty bank account
                Losi do metric and imperial sets of both hex and nut drivers, I have a full set of both
                  I've been using a set of the Century hex drivers for a couple of years now and the 1.5mm driver is still in good condition.
                  Steve H
                    Thanks for the advice. Ordered a set of Robbe Hex drivers including a 1.3 from Midland Helicopters.
                      Century hex drivers are good but there hellis are poooo , thats ironic
                      REGARDS JAMIE
                      Knight 50,50 hiper,hatori pipe,gy401+9254,ttcarbon blades futaba ff7fast 2.4 ghz set up with 3152 digi s all round and a rev loc 10
                      450 rex standard setup
                      Phoenix sim...
                      Plus two gliders and one pits special biplane
                        I dont use hex drivers for hex screws. Get a full set of mini Torx drivers. They fit PERFECTLY and because of the extremely good grip they give there is no chance of rounding either the driver or the screw. Discovered this whilst trying to come up with a way of getting soft hex screws out after 3 years and red Locktite at work.
                        Blade 400 3d :cool:(10 flights and counting....)
                        Walkera 4#3 :cool:( Half way to brushless!)
                        Twister Medevac (Broken):angelsad2:
                        PiccoZ (Still Fun)
                          hi dave
                          found a great set of mini drivers at maplins electronics 33pcs extending handle ,tried them and they seem very good code no L94BQ £19.99 also picked up 1.3 & 2,0 hex from buck & ryan made by bondhus using protanium steel havent had an issue with them yet hope this helps
                          brian
                          a good day is a heli day
                          Trex 550e dfc :-)
