Should be getting my T-Rex 500 delivered tomorrow. Apart from screwdrivers etc can someone list what you need for the build . Do i need oil ? Is loctite is included in the kit ? Is Acetone ok to remove oil from screws etc.
T-Rex 500 build
loctite is included in the CF version kit.
no oil needed
I do recommend you register at www.helifreaks.com
and watch the bob finless build video's well worth watching
| 3D Championship
A medium thickness cyano acrylate (CA) glue such as zap-a-gap works fine and doesn't go off too quickly (the thinner it is, the faster it goes off!)
Use blue threadlock on metal to metal parts (bolts into metal housings etc), and CA glue on metal into plastic parts.
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
Originally posted by robgt View PostA medium thickness cyano acrylate (CA) glue such as zap-a-gap works fine and doesn't go off too quickly (the thinner it is, the faster it goes off!)
Yep I do exactly the same
