Gasser SE Removable starter......
  • Gasser SE Removable starter......
    Hi
    Question on the Gasser SE you can fit the removable Starter.
    So is it better to fit starter permenant or make it so it can be
    removable? Instructions list both but unsure which way to
    go with it.
    need to choose before I start the build.....
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
    whats the advantage of the removeable? Does it save much weight?
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
      Hi
      it will save a bit of weight if made removable....
      Plus If I add the Tuned pipe I'll get another 10-15% out of the
      engine!!
      The engine is just Massive!
      Oh also picked up a futaba 601 and 9521 tail servo for it.
      Mark
        I have a removable pull start on my Spectra G pictures in my gallery.
        The only thing you can do wrong is forget to remove it after starting -- my mate did and it fell off and had to be replaced.
        Dave
          Hi
          its going to be fixed on, thought of loseing it not good.
          Plus getting tuned pipe so the extra power will eliminate the
          pull starts weight....
          Mark
