programming software for zyx
  • programming software for zyx
    is the programming softeware the same as the upgreading software?
    I've ended up with a *.bin file. Dunno what to do with that.
    Some of the files form hobbyking are unreadable zips.
    Can a zyx enthusiast point me to the right sofware downloads? (that will work with windows7 x64).
    Gordon
    Gordon that looks like a binary file probably the application that needs to be sent to the device by either the programmer or via USB to the bootloader.
    I have never flashed a zyx although i have one here
    Steve
    Steve...
    Outrage RC Field Rep
      That sounds like it's just the firmware file.
      Everything you need is here... PC Software for Setup/Programming the CX-3X1000, 3GYS, TG-1, ZYX etc. - RC Groups
      I personally use this software for the programming... Flybarless Gyro Programming Software - it's an unofficial one but it works well
        As Gixxer says - use John_NZ's software for programming / upgrading, it is much more reliable that the Tarot PC software. The file ZYX-350.bin is the latest firmware to download to the ZYX FBL unit
          Thanks for the info folks
