Tarot zyx
    does it need digital servos on the cyclic ? like the 3gx
    Sab Goblin 500
      no you can use analog all round if you want:
        Makes me jealous that I've not got mine done yet.
        Feels like I've lost my mojo
        Park Hall Helicopter Club
          anyone else got one on a 450 pro?
          thinking of getting this and a DFC head
            Hi, I have had one of these on my tarot 450 pro for a few months now And have had zero probs with it. All my settings were as the manual stated and all i had to change was the gains on aileron and elevator a few points down.The heli feels well locked in now, much more than it did with a flybar.
            This vid is of its first flight before tweeking it, btw I'm no hard 3d pilot.
              can i ask - does this need a separate receiver? or can this use satellites and eliminate the need for a separate receiver?
              EDIT: i've just searched - this version needs full receiver. there's a new Tarot ZYX-S out now that has support for satellite
                Finally got mine fitted tonight. Think it's all setup correctly but a little confused on the pirouette compensation. What should I be looking for with this. EDIT (Think I've sussed this now)
                Have to say that the USB or programming box are a must.
                Just got to setup pitch curve then a test flight.
                  Well just given it a test flight and wow is it twitchy. It's my first flybarless so I'm a little twitchy myself at take off as I've heard so many things about them tipping over. One thing I did notice is that I cant run a high gain on the gyro otherwise it starts wagging like a dog. I'm set at 60% in the tx. maybe I need to have a faf around in the software.
                    keep the updates coming. i bought it the other day. hoping to pair it up with a 450 dfc head.
                    • #25
                      I would move the servo ball in. I have found the suggested servo ball positions unworkable on my configuration. My initial setup used the suggested positions and I have violent oscillations, even with the gains as low as I dared. Once I moved the balls in (on mine, they're as close as possible) the setup now works
                      • #26
                        Will double check my balls :-)... I think they are fairly close to the book figures already but can harm to check again.
                        • #27
                          any more updates? mine should be arriving next week and i'll order the dfc head (altho i ordered the cheapo $10 fbl head from HK as well) when it comes
                          • #28
                            Not from me. Poor weather, DIY, kids and work has been pretty prohibitive on me getting any heli time.
                            • #29
                              I'll update - i've been suffering horrendous elevator bounce - the culprit (and this will prob teach people to suck eggs) was CofG - I understand most flybarless units are very sensitive to CofG so double check this guys
                              • #30
                                Thanks for the tip. Will check mine.
