Tarot ZYX FBL controller - first test with Trex 250
    This is what I use on my 250 with the XYZ ... Pitch and Roll gains both 26 (default is 40)
    [section1]
    PitchAgility=35
    PitchGain=26
    RollAgility=35
    RollGain=26
    YawAgility=35
    YawRight=35
    YawGain=100
    [section2]
    FixMode=1
    ServoType=2
    SwashPlateType=2
    ServoDirCH1=-1
    ServoDirCH2=1
    ServoDirCH3=1
    ServoDirCH4=1
    ServoAdjustCH1=33
    ServoAdjustCH2=27
    ServoAdjustCH3=4
    AileronLimit=80
    ElevatorLimit=80
    TotalCoefficient=70
    PitchDir=1
    RollDir=-1
    YawDir=1
    TailPoint=0
    TailLimitA=105
    TailLimitB=96
    OptimizationDir=-1
    [section3]
    Acc1=125
    Acc2=55
    Acc3=125
    Acc4=125
    Acc5=25
    Acc6=25
    DeadBand1=15
    DeadBand2=4
    DeadBand3=20
    DeadBand4=4
    PitchGainD=15
    PitchGainI=80
    PitchGainP=80
    RollGainD=15
    RollGainI=80
    RollGainP=80
    SpinSpeed1=35
    SpinSpeed2=35
    SpinSpeed3=35
    SpinSpeed4=35
    TailCompsate1=0
    TailCompsate2=0
    TailGainD=30
    TailGainI=50
    TailGainP=80
    [FBL]
    Preset=0
    ModelName=
      Is it beter to set it up with the programming box or buy USB and pc?
        A the very least get the usb dongle - that way you can save your settings, I also bought the programming box and it is very handy
          Where did you get the programming box from. I seem to only be able to find ones for the copterx unit.
          Park Hall Helicopter Club
            I have the box. Is it worth getting USB dongle aswell.
              Programmer ... AC-RC Hobby
              Tarot ZYX Program Card for XYZ Flybarless 3 Axis Gyro
              I would say definitely get the usb dongle as well - I recently swapped 2 units, dead easy save the settings from original ZYX, take it off, download settings into new units, plug in, fly
                Tarot 2012 Latest ZYX-S Flybarless 3 Axis Gyro Systemhat are the advantages of the S system?
                  Can anyone tell me the firmware update procedure (in English)
                  Dan
                  Goblin 500
                  | Blade 130x | Blade 180cfx
                  Spektrum DX8
                  GWR Pilot 2011 & 2012
                    This is what I found on the hobbyking website.
                    TAROT ZYX gyro firmware upgrade
                    1.Add the RC signal verifying when initialization,prevent ZYX from fault caused by error of initialization.
                    2.Fix the assignment issue of RC trim signal when the swashplate type was selected as mechanical mixer.
                    Firmware upgrade instruction
                    1.Connect the ZYX gyro to PC by ZYX USB adapter,click "Connect ZYX",make sure it succeed.
                    2.Open the Firmware in ZYX PC software.
                    3.Keep the PC,USB adapter and ZYX gyro connecting.Power off ZYX gyro,press "SET" button of gyro and power on.
                    4.The red lamp is flashing,click "Upgrade" button to start upgrade,the ZYX gyro will restart after successful upgrade.
                    5.Please make sure your gyro is Tarot ZYX,otherwise the gyro will be damaged.The ZYX gyro does not need to be setup again.
                    • #25
                      Dan
                      Goblin 500
                      Spektrum DX8
                      • #26
                        How well does the zyx work? I have one on order to play with as I'm still fully flybarred
                        • #27
                          Does anyone have a link to a manual? These prices are just silly. I'd like to know how much the stability can be tuned to make it easier for learning.
                          Blade 130-X, MSR, MSRX
                          Phoenix Sim
                          • #28
                            Here you go : http://www.infinity-hobby.com/main/d...ZYX_111012.pdf
                            If you haven't got the USB connector I recommend you get hold of one, so much easier than using the Tx
                            Dan
                            Goblin 500
                            Spektrum DX8
                            • #29
                              Yeah, its deffo a lot easier with the USB programmer so if you get one from HobbyKing or Hawk-Rc its worth buying together (only an extra £5) but, when I first got mine I followed this tutorial and was happily flying it on the 450 pro with stock settings.
                              P.S I have a spare unused USB programmer you can have for £5 if you don't want to wait on the slow boat from China...
                              • #30
                                Qq
                                Aa
                                x 3
