For the cyclic direction instructions the VX1 Setup Guide states:
So on my Gaui X5, if I wiggle the right cyclic stick, aileron moves in the wrong direction, but, if I lift the helicopter and wiggle the helicopter back and forth the VX1 attempts to compensate correctly (i.e. the swash plate opposes the direction of travel in an attempt to keep the swash plate level and does a pretty good job). If I follow the above instructions and correct the swash plate control movement through the VX1 instead of the transmitter, then, if I wiggle the right cyclic stick, then the swash plate moves in the right direction, but, if I wiggle the helicopter then the VX1 attempts to compensate incorrectly (i.e. the swash plate moves in the direction I rotate the helicopter, rather than opposing the moment).
The only way that I get get the correct behaviour, is to correct the swash plate control movement from the transmitter and put the VX1 cyclic direction back to its original value - that way, if I wiggle the cyclic stick, the swash plate moves in the correct direction, and if I wiggle the helicopter the VX1 attempts to compensate correctly. Is the manual wrong, or am I missing something?
I have the same problem with the tail. The VX1 Setup Guide states:
But if I do that then if I turn the helicopter left, then the pitch change on the tail blades does not attempt oppose the movement, but instead puts the pitch in the same direction as the left movement. The only way to get the correct behaviour, is to reverse the rudder in the transmitter, and put the VX1 Tail Direction back to the original setting. Again, is the manual wrong, or am I missing something?
Thanks,
Andrew
Operate the cyclic stick and select the option that makes the swashplate move the correct way.
Operate the rudder stick and check if the tail rotor pitch moves the correct way. Reverse this parameter as needed
Thanks,
Andrew
