Hi all, has anyone set up the Vortex with a JR DSX9 on a Nitro?
I'm using Speccy sats and the vortex Governor & Spartan sensor on my Trex600n,
Are all of the Gov settings/gains done on the DataPod, with no need for a channel from the tx?
As I've just used the Governor mode on my Tx to match the flight modes on my Tx to the flight modes on the Vortex as explained below...
(my Tx is a JR DSX9, But the menu's shown below for the JR X9303 are the same).
Other Tx's are shown here Spartan RC
JR X9303 (as proposed by Bob O @ HeliFreak)The X9303 does not offer individual gyro gain value for four different flight modes. Instead we can use the governor function to control the active flight mode of the Vortex.Hold the ENT button down whist powering on the radio. In the menu locate "DeviceSEL" and open it. Under GEAR change the OUT: option to GOV as shown in the photo. Exit the Setup menu and enter the Function List by pressing the LIST button. From there select the Governor option. Set the percentage value for each flight mode as show in the photo.
In the DataPod Home Screen or Setup::Transmitter menu confirm that the Vortex is tracking the radio flight mode correctly. This method has been confirmed to work using satellite receivers. When using a standard receiver with individual channel connections the percentages may need to be slightly altered.
To check that the flight modes were matched I did the following test...
I set the high end of my throttle curves (IN100 OUT100) to the following,
Norm ~ 50%
ST1 ~ 75%
ST2 ~ 100%
Hold ~ -5% with a delay of 2.0 seconds
Then on the DataPod I went to the transmitter live screen, with the throttle stick full up (100%) I clicked through the idle up's and hold, the throttle bar on the DataPod was reading what I'd set modes too in the TX.
When I hit hold in ST2 the throttle bar dropped quickly down 0%, then when I released hold the bar moved smoothly back to 100% due to the 2 sec delay.
So back to the Governor, is it all set in the Vortex via DataPod & the same with the Gyro???
Cheers Guys
(I Think Wavey Davey may have mentioned the DataPod)
Question #138 How do I set my transmitter so the flight mode (Normal, Idle1, etc) matches the corresponding mode of the Vortex?Answer |
In the DataPod Home Screen or Setup::Transmitter menu confirm that the Vortex is tracking the radio flight mode correctly. This method has been confirmed to work using satellite receivers. When using a standard receiver with individual channel connections the percentages may need to be slightly altered.To check that the flight modes were matched I did the following test...
Norm ~ 50%
ST1 ~ 75%
ST2 ~ 100%
Cheers Guys
