Vx1 questions
  • Vx1 questions
    How are you powering the Spartan vortex, it looks like there is only one power plug available and can you have aux2 for a switch glo?
    Goblin black nitro, Trex 700N, Vbar control 👍🏻
    You have the Datapod port to use for power in as well.
    You'd need to use the signal from Aux3 for the SwitchGlo, but you can't take the power from there so you'll have to get that elsewhere.
    If you are using Futaba S.Bus then it is not an issue as you can plug the SwitchGlo into the receiver and move one of the other channels out of the way if necessary.
      Vx1 questions
      I'm using a Perfect Regulator Trio at the moment, so I have power feeding the Vortex via the Aileron, Elevator & Pitch ports.
      I think if you look at the set up guide it does mention about using a remote glow and what channel to use.
      WEA-TTI-TMFC........
        You can also use SV5 as I use SV5 and the Datapod for my Master and Slave of my ESC
          i normally put 1 wire into the RX and 1 into the pod port on the vx1 once setup.
