Hi Guys and girls I am trying to find a satellite Rx for the vxn1 on dmss as their is no room for a full size Rx in the fireball Align do 1 for the trex 150 on dmss is this any good for a bigger heli ,jr do 1 but has 4 wires any help appreciated Thanks Richard
VX1 and jr dmss
Yup, you can use the RA01TL/RA02TL sat, but you have to bind it first (which requires all 4 wires connected) before connecting it up to the vortex with 3 wires.
https://www.helifreak.com/showthread.php?t=734404
I'll do a bit of digging for you later, but I'm not sure, I don't use DMSS myself. I would imagine that you use the 4 way connector housing into the Sat at one end with one wire removed, and the spektrum 3 way housing at the other,going into the vortex, but of for how it's wired.....
I read in another thread on HF that only one model of DMSS Sat is supported, but I'm not sure what sat that is, so hold fire for now, and if I need to, I'll ask Angelos for some guidance.
This is all I've found so far:- DMSS and SK540 Connections - Skookum Robotics WikiOriginally posted by glenflyer View PostThanks the spectrum sat lead fits in the dmss sat leaving 1 pin of but it's what pin you don't connect am worried that I might burn something out if it is the wrong way
https://www.helifreak.com/showthread.php?t=455583 (See post 11)
Need to get some actual work done now
