Full Size VX1 on Align 550e
  • Full Size VX1 on Align 550e
    Anyone running this combo and if so any chance of a pic of your install. Theres not much room at the back for main unit, sensor and Rx. I can squeeze it in but looking for inspiration
    put sensor on front on the metal plate
    Santander Factory Team
    Proud wearer of 5 x EGS
      It's the DFC version Brian and everything is at the back, so I can sit the sensor on the elevator guide and stick the main unit on the carbon shelf but then I'm struggling for the Rx, I can put it on the side but then I'm struggling how to neaten it up without having a wiring scheme like a demented thrush had been in amongst it
        s
          sensor on front mount, control unit top of tail boom case and rx on bottom carbon base plate
            Can't see pic mate
              Can't see pic mate
                How strange mine isn't like that, the plate you've got horizontal is in line with the front frames pointing towards the battery tray.
                Sussed it, the plate your saying at the front of the model should be over the top of the servos it's not on mine but thats easily changed. Cheers
                  its the one before dominator
                    Yep, I've got it the bit your highlighting isn't in the right place. Cheers food for thought
                      The Trex 550 with 600mm boom is very tail heavy dave,I try and keep the electronics as far forward as possible,even moved my mini vbar up front which makes the wiring a bit tricky.Even like this I still have to run the battery quite far forward as shown.
                      Trex 550 Dfc v3 with Mini Vbar on Pro.
                      Trex 700Dfc,Vbar Neo on Pro.
                      Mk Heli Club Member.
                        By end of finger
                          Slightly out of scale mate, can't see exactly where you mean
