VX1N Problem
  • #31
    Originally posted by KevDavies View Post
    Took me a little while to get my head round it Brian when I got the first one. But setup is really easy. Once youve set a model up once for a Vortex unit in the radio, you can just copy it to another model memory. No more messing with transmitter setup.
    And the heli setup is really simple, you only need a swash level (or mk1 eyeball) and a pitch guage
    im sure I can manage it, but if and when I fit it, if I'm stuck will call on your services.
    Santander Factory Team
    Proud wearer of 5 x EGS
    • #32
      No its Spartan it reads LOL
      No worse that the stout V-bah fanboys! Infact I know one of them who is a much bigger tool than I!
      raptor 90 vortex
      goblin 770 vortex
      goblin 630 vortex
      knight 3d vortex
      trex 450 vortex
      you see why i said vortex and not spartan
      you are mr stig of the vortex
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
      • #33
        Originally posted by GIXERMAN View Post
        I've had a vx1n for some months, just haven't had the heart to remove a Vbar, doesn't seem as easy to setup as people say, or am I reading into it.
        Not sure why you would remove one perfectly good FBL unit for another unless there were other factors!
        That said, the vortex is pretty easy in truth. I think the documentation could be made more "new-to-vortex-friendly", but that's a comment about the manual, not the actual setup procedures of the unit itself.
        Sent from my iPad using Tapatalk
        • #34
          because I like to try new things tom, also bought a skookum 540 to try also but as yet not fitted to anything. I've had a ebar,3G,3gx, beastx ,brain and Vbar so far, so may aswell try a couple more.
          • #35
            Lol we wandered what those odd noises were coming from your tent.
            Goblin 500 SK540 jive 100lv
            HD 500 SK540 jive 80 lv
            Oxy 3 SK540 minijazz20
            • #36
              Can't beat a fiddle graham
              • #37
                Fair enough! As I say, the VX1 setup is actually easier than the documentation implies. My first one wasn't a great experience as my datapod came with incompatible firmware against the main unit and required a firmware upgrade. Not great for a mac user when the software is windows only!
                That was a very early VX1 unit though. My second unit (a VX1n) was trivial to install and setup.
                • #38
                  For me the biggest difference was that with the Vortex you must calibrate the TX to the Vortex first otherwise you'll be chasing yourself around in circles. Once all the travel adjusts and servo directions are set and everything moves exactly as it should in the Vortex it's very logical from there on. Having said that, there are lots of things to tweak and it requires reading up on what some of the functions are for things like paddle dynamic and style etc.
