So, for the last couple of months I have had quite a journey with the Vortex, and thankfully the story has a happy ending
The story starts with me scrabbling around for £250 notes to buy my 7HV airframe of Rocket Ronnie, selling my Electric Knight back to Trillian and finding myself either 'having' to put my 3Gx on the 7HV, or getting another FBL unit.
So onto the doorstep arrives a Fubar.
I had second thoughts.... for a few reasons.
1) do I trust it? 2) Is it right (its essentially a rip off, but then so is the YEP120HV I fitted to the 7HV)
So while I am ummming and ahhhhhing...... Mattie Lodge puts temptation in my way
"Do you fancy borrowing a Vortex, see if you like it? Its a different feel to your Vbar but I think you might like it" or words to that effect...
So the deal, I get a brand spanking new FBL unit to borrow and use, and all I have to do is let Mattie know what I think of it, so you can guess how long that decision making process took.
So next dilemma - which heli?. I have an align 600e, that started off as a flybarred kit, that I converted to the DFC head, and the new 7HV that I had never flown. Mattie suggested putting it on the 600, as I knew how it flew on the blueline Vbar pro and could compare and contrast. Actually the decision making process was all down to the fact that the 7HV's canopy has VBAR written across the front, but dont tell Mattie....
Well the VX1 I had was running on beta firmware, rather than the V1. The setup was utterly straightforward, the datapod really easy to use and although my first thoughts were this is going to be fiddly and awkward, I way preferred this to fiddling about on a laptop. It was good to go in about 30 minutes.
Now the bad news..... I had spent two months trying to iron out a single odd problem, and never really got there until today.....
I read threads saying that it took a lot of tweaking to get right, and so lots and lots of adjustments, but I couldnt get this odd characteristic out, the nose would bob just a little in forward flight, and during flips it would 'judder' and then continue to bob for about a second when back stationary.
Rotor gain, ele precomp..... all adjusted, better but not quite right..... new beta firmware - a bit better maybe? V2 - still the same
I was pretty much set on handing it back to Mattie, with a polite - "thanks, but I cant spend any more time trying to get this right." But.... apart from this issue it felt so much 'sharper' than the Vbar I had been used to. Mattie had been really helpful, showing great patience, but really wanted me to get it ironed out. We were both scratching heads. A secret group of clever people (I call the Masons) were scratching their heads --- Check dampers, think about changing blades.
So huffing and puffing, I change the dampers.
Instantly solving the problem, as I had the wrong bloody dampers installed.
I put some of Matties edge blades on (on a you break them I break you basis of course), and wow the heli really comes alive (I had been using regular TT blades, the £30 ones).
In short, this heli is now ******* brilliant. I feel a bit stupid having spent two months faffing around when all that was wrong was £3 of dampers.
Thank you Angelos, for all the work you have put into this. V2 is awesome straight out of the box (with the right dampers), all I did was tweak the rates.
Thank you Mattie, for the lend of the Vortex, all the help, and the loan of the Edge blades for testing. I gave the blades back pretty quick didnt I, I dont think im going to be quite so quick with the Vortex... you may have to wrestle it off me....
So if anyone wants to swap a Vortex for a full size Blueline Vbar Pro, you know where I am, your loss will be my gain
disclaimer: Im not sponsored, nor have received anything for writing this, just wanted to share my experience. Unfortunately I will have to give the Vortex back at some point
and a platinum star
