The awaited V2 for the VX1 is now on the Spartan site for download
V2 now avail
* Added automatic Pitching Up Compensation for high speed flight. New parameter in Rotor menu controls the magnitude of compensation.
* Improved tail acceleration/deceleration/reversal algorithm. The default values for tail acceleration and deceleration have also been updated to match the algorithm.
* Improved cyclic acceleration/deceleration algorithm. The default value for Rotor Acceleration, Deceleration have also been updated to match the algorithm.
* Improved tail stops (also see notes about trim flight). The default values for the tail stop gains have also been updated.
* Trim flight also gathers data about tail hover torque to equalise stop behavior. It is moved to system menu as its function now spans across both main rotor and tail.
* Throttle output (SV5) does not get activated until the radio has linked. This allows ESCs to enter program/calibration mode when stick is high.
* Failsafe now requires a longer duration of signal loss before it activates.
* Added new receiver type "UDI". The receiver option auto-detects various protocols including the upcoming JR XBUS.
* Added 135 degree swashplate and improved the 140 degree.* New V2 main rotor algorithm provides excellent out of the box performance.Last edited by dw45; 05-08-2013, 11:29 AM.David
Kyosho Concept 30 still going just
T Rex 450 V1 GY401
T Rex 450 Pro FBL DFC AR7200BX
T Rex 600n compass FBL head Vortex N
Srimok 90N FBL VX1
A EGS for me shucks X 2 to treasure.
WoooHoooo!!!
Ive been waiting for this before I buy a Vortex!! Nothing stopping me now LOLSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Collector of SAB Goblins
Just reset up my Rave with the V2 code installed as it's a full setup jobbie as it's gone from M3 to M4 protocol
For some reason I've had to bugger around with the servo horns as the Vortex has now decided that they're not centred correctly, even though they were fine on V1 code
Nothing changed between the M3 and M4 in respect to servo centering. Perhaps your servo pots worn out a bit since the last time you did setup?Originally posted by steve_b View PostJust reset up my Rave with the V2 code installed as it's a full setup jobbie as it's gone from M3 to M4 protocol
-AngelosSPARTANRC - R&D
Any gotchas / things I need to know to upgrade mine from M2 ?Tom
You need to do a full setup again because it's gone from M3 to M4 protocol, but that's mentioned on the download site anyway. I've had to tweak the ail & ele debounce and cyclic gain, but other than that nothing else.Originally posted by tomatwalden View PostAny gotchas / things I need to know to upgrade mine from M2 ?
V2 flies so much better than V1 in my opinion and it's sorted the tail bounce problems I had with V1 so I'm happy with it.
Result.Originally posted by steve_b View PostYou need to do a full setup again because it's gone from M3 to M4 protocol, but that's mentioned on the download site anyway. I've had to tweak the ail & ele debounce and cyclic gain, but other than that nothing else.
V2 now avail
I've been using it since the MK flyin and it pretty much transformed my g4 to almost plug and play. The tail was spot on once I'd done the trim flight to. Just need to do an update from beta edition to full release now.Invertix 400
Vortex 285
TBS Discovery Endurance
X4 II
Schluter Champion Longranger
G4 E720
G4 E720 Big AIR edition
Goblin Urukay super slow
Goblin 700 KSE Slow
Goblin 700 KSE Fast
Srimok Faifa
Spectra G
Synergy 766
http://mangled-rc.com/
V2 now avail
Quite! I already like the way my Goblin flies. Looking forward to seeing the difference this makes.Originally posted by Tim Procter View PostResult.
transmitter settings stay the same. You just redo the swash and tail setup on the datapod.Some say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
And governor (even if you're not using it). Mine lost the "analogue" tail servo setting (required for brushless ESCs).Originally posted by KevDavies View Posttransmitter settings stay the same. You just redo the swash and tail setup on the datapod.Tom
