nitro throttle help needed ;O
  • nitro throttle help needed ;O
    hi im trying to set up my vx1 and I just cant find any info on how to set up the throttle
    I know im thick I just cant help it lol could some 1 do me an idiots guide
    I don't under stand the idle end point (not sure if this is for idle or cut)
    also how do you set up throttle cut.
    thanks for any help as u can see simple things confuse me so this needs to be real simple but detailed lol
    cheers terry
    I may have sorted this I pop back in a min
      Wind your trim to the bottom and then with your stick at bottom set the idle point so that you just start to bind and then back off 1 or 2 points. Go back to mid trim and then set the throttle min for your tick over.
        you don't want to use any trims from the TX, so you set your throttle throw top and bottom with these idle and high as in the set up guide governor section, you set the throttle cut on your tx as per normal way from your TX menu.
        David
        Kyosho Concept 30 still going just
        T Rex 450 V1 GY401
        T Rex 450 Pro FBL DFC AR7200BX
        T Rex 600n compass FBL head Vortex N
        Srimok 90N FBL VX1
        A EGS for me shucks X 2 to treasure.
          If you do that with a DX7 and your trim centered you may over drive the linkage and bind when you cut the throttle, IE wind the trim to the bottom.
            right in that case I think I done it correctly
            throttle stick top carb fully open
            stick all the way down carb closed (set via vx1 endpoints)
            throttle curve raised at bottom stick for tick over
            throttle cut set at 0% cut throttle (carb closed)
            been awake since 11am yesterday and pulled a 13 hour shift so hope that makes sense (as I don't normally WITH sleep
            cheers terry
              throttle now reset as per andys instructions (thanks andy )
              max end point carb fully open min idle or max idle (what ever it says) engine idles tx switch set to -19% and throttle cuts
              test flew in the wind not ideal but got me out the house (think it needs some major tweaking) so come on weather brighten up I got some learning to do
              also thank you to wavey too also dw
