SK540 + Futaba BPS-1
  • SK540 + Futaba BPS-1
    Has anyone tried using the Futaba BPS-1 with a Skookum and got it to work?
    I understand that the sensor won't work until the engine is running, so if you turn over by hand you wont get a signal - not like a Spektrum sensor or the standard futaba sensor.
    I have returned 1 to Ripmax already and they sent me a new one, but it still doesn't work
    Re: SK540 + Futaba BPS-1
    I believe it won't work from what I've read sorry
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
      Just tried the Spektrum backplate sensor and it works perfect. I've still got the Futaba BPS-1 sensor mounted.
      danch where are you reading about the BPS-1? Because futaba won't give any detailed info and Skookum say that it should work
        This is far from the only device that can't use the BPS-1.
        I noticed when looking at the documentation for the Spartan Vortex that Angelos has noted that the BPS-1 will not work as it is an 'they are analogue type'.
          Read a couple of threads on helifreak were s few people had tried the futaba sensor without luck
          Goblin 500
          Spektrum DX8
