What BEC with your Skookum
  • What BEC with your Skookum
    Is anyone running an external BEC and NO powerbus with a Skookum - if so what bec are you using and how did you find the wiring.
    Regards as always
    HV..BL9080 AND 9088 ... 2s straight into power bus and a link between both sides... one on a 720 one on a 540... just the sbus is in a strange place on a 540 (portb)...
    No regs... i fit a standard futaba HD switch between the fright pack and the power bus... first pack went dead flat because it wasn't unplugged for a week... now we use a switch...
    Steve
    i really should read the post properly before posting !!!
    Steve...
    Outrage RC Field Rep
      I was using a SK720 on my 600 with no powerbus - just a 2s life pack straight into it and no problems while i had it.
      Gaui X5 - Spartan Vortex
        Using a 2S lipo pack straight through with my SK540
        I am here: http://tapatalk.com/map.php?tad2p5
        Goblin 500
        | Blade 130x | Blade 180cfx
        Spektrum DX8
        GWR Pilot 2011 & 2012
          Regards as always
          The answer to your question is very much dependant upon the size of the heli.
          What heli are you going to run this Skookum on?
          Due to the amps that full size servos will pull, Skookum recommend the external bus on 550+
          Sent from Android using Tapatalk.
            Dump BEC, go with LiFe or Lipo
              Gryphon quaser here on 2 helis. 1 720 with power bus and 1 540 without.
              Just setting another heli up with western robotics super BEC on 720.
              Never had a problem.
              Goblin 500 SK540 jive 100lv
              HD 500 SK540 jive 80 lv
              Oxy 3 SK540 minijazz20
                weston Robotics Hercules super bec with no bus and a sk540 on my goblin 630.
                Bullet proof bec would highly recommend it.
                not cheap but ive Never been one for scimping on components
                Goblin T600E pro T550 T500 T450 Pro
                All ModelGuard protected
