SKOOKUM 3.10 is here -
  • SKOOKUM 3.10 is here -
    New update available:
    New features are:
    * Allows for 2x faster bail out self-level
    * The high-vibration warning is only enabled if self-leveling is active on at least one bank
    * Users can re-level the accelerometer themselves (The center-point can drift over the long term. This feature is meant to be used rarely).
    * Quad copter mode (See wiki)
    * JR DMSS mode (requires simple adapter cable, see wiki)
    * Better vibration filter on the tail
    * Option to disable the governor while in tail bank 2, for nitro engine tuning.
    * Improved PPM receiver signal capture
    * RPM capture enabled in PPM receiver mode
    * Accelerometer is more static-electricity resistant
    * Fixed a bug in Graupner mode channel mapping
    * Fixed a bug in fail-safes for the aux servo outputs
    * Several minor bug fixes
    Changes to the Setup Software, rev 3.10:
    * Supports the SK540
    * Support for upgrades as described above
    Changes to the LCD Firmware, rev 3.10:
    * Several bug fixes
    Changes to the Data Viewer, rev 3.10:
    * Fixed bug that prevented some users from registering without help
    WOW X2 bailout speed increase, can't wait to try it.
    Regards
