Skookum SK-720 Your Thoughts?
  • Skookum SK-720 Your Thoughts?
    Hi,
    Is there anyone out there using the SK720??? If so, how are you finding it? I've read there is a tail wag problem with the new V2 Update... And that's the only problem I've read about! Are there anymore I don't know about?
    It's between this and a BeastX for my next project!
    Shaun
    shaun stop mucking about and get a v-bar please
      I knew somone was going to say that!! My only problem with V-Bar's.... They are like dog sh*t!! It doesn't matter where you look, there's a V-Bar!
        Originally posted by Bart101 View Post
        I knew somone was going to say that!! My only problem with V-Bar's.... They are like dog sh*t!! No matter where you look, there's a V-Bar!
        i think you will find that is more for Align helicopters but if true it speaks volumes dont you think anyway ive got two so you should at least own one,and as im a god i instruct you to get one now!!
          Ok V-Bar = Dog Sh*t of the FBL world!
            I have three 720's and i really rate them. I used to have vbars.
            I am just testing a new firmware 2.03 which has solved the tail wag a few people including myself have had. My tdr rigid took on a bad wag after the last update but is running fantastic now. Best tail ive ever tried. The sensors used are of a higher spec than other systems. Vbar for instance has a max controllable yaw rate of 520. The 720,s is 900. Cheap sensors are possibly the reason the beast x has some bad press in fast piro moves
            Goblin T600E pro T550 T500 T450 Pro
            All ModelGuard protected
              also i think if your going to go for your b cert Shaun you cant use a system that can self right your model (active flybarless control ) and i beleve the sk720 has this ability so not sure if it can be used ? well not for taking your test anyway
                I asked bmfa about that and they said as long as you show that this isnt engaged thats fine. an example would be to let the examiner test fly it or show on a laptop or hand held controller that the box for self level isnt ticked.
                I use self level on a switch as a bale out when my old eyes loose orientation at a distance.
                This is me flicking the switch when inverted.
                [ame="http://www.youtube.com/watch?v=uNq0V4_r0oU"]YouTube - SK720 inverted self level[/ame]
                  Nah that's the YeastX.
                  Seriously though that's like saying Avant = Dog Sh*t of the heli world (well North of Watford anyway)
                  I too would like to try a SK720 even though I have 3 Vturds already.
                  Mikes Place - Home of the golden dump.
                  Sponsored by Elite Models.
                  http://www.elitemodelsonline.co.uk/
                    I would have thought, as swashbuckler says, that BeastX is the dog turd of the FBL world, in terms of you see them everywhere. And, IMO, that is simply because you can't beat it terms of value for money. I'm not saying it's the best FBL unit however
                    Harry
                    Powered by Futaba 18SZ
                      beastX definately the best value for money.
                        Cheers guys!!
                        Can you use it with Spektrum Sat's like the V-Bar??
                          Cheers guys!!
                          Can you use it with Spektrum Satt's like the V-Bar??
                          Sk720 definately works with spectrum sats and Futaba Sbus
                            I have got a SK720 on a RJX50.
                            The SK720 has a reputation of having one of the best tail performance in the FBL business.
                            It's now got a brilliant wizard, that if you follow it to a "T", will give you a 100% flyable model with no nasty surprises.
                            After that, you adjust it to your personal preferences.
                            It has some excellent features like:
                            1) 2GIG memory card which would give you a huge amount of logs.
                            2) Required PC Software installed on the card
                            3) Initial programming can be done using the SK720 hooked up via USB to your PC, without any servos or external power requirement.
                            4) Powerbox.....on 50Nitro/600 upwards a real advantage as now just signal is required from the SK720, while all the heavy load to servos etc, can be distributed via this box. Both high and low voltage can be used.
                            5) Direct visual indication if your vibes are a bit high via a red/green blinking LED on the SK720 itself
                            6) lots of other stuff, with more to be released in the future.
                              I've heard they are going to release a GPS module. It has auto-pilot, altitude hold feathers.
                              Hope the price is right.
