Hi, just wondering will the sk540 work with an old dx6i
sk540 and DX6i
Spektrum/JR Sats are the default setting for receivers in the SK 540’s interface. Newer Spektrum TXs (DX7se and newer) use 2048 resolution, older (DX-7, DX-6 and older) use 1024.
Figure 6 - Be sure to specify your Spektrum/JR receiver's resolution.
The above I would say means yes, taken from manualSantander Factory Team
Proud wearer of 5 x EGS
dx6= no its dsm
dx6i=yes
its dsm2 or latterly dsmx. which the skookam is compatible with.
Hi, thanks. Someone told me due to the 6 channels i would not have control of tail gain do you know is this true also do you know of any problems i could have due to 6 channels. Or will it be a normal installation. ThanksOriginally posted by GIXERMAN View PostSpektrum/JR Sats are the default setting for receivers in the SK 540’s interface. Newer Spektrum TXs (DX7se and newer) use 2048 resolution, older (DX-7, DX-6 and older) use 1024.
You'd either have to choose to have a cyclic bank on your gyro switch or tail. It would be better to have this set for cyclic as unless your flying rate mode and HH, or high and low head speed you will leave the tail once set.
Cyclic banks are very useful for fine tuning.
If you get stuck and need a answer quickly please pm me as that would be quicker.sigpic
Goblin 500 SK540 jive 100lv
HD 500 SK540 jive 80 lv
Oxy 3 SK540 minijazz20
