servo throw on msh brain
  • servo throw on msh brain
    anyone point me in the right direction with adjusting the amount of throw on cyclics with the brain? i have much more travel than id usually have and cant seem to alter it in tx? or should it be altered in the actual program, the different flight modes i.e. beginner to hard 3d dont seem to change cylic throw just speed it up, any advice guys thanks
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    the throw should be altered in the cyclic page in the software not in your tx.
    its the page where you can centre your servos, you can also in the same page change pitch range and cyclic throw.
    All the best
    Tony.
      So basically where the guy in the ikon video says to set everything to 100% I can set lower values which will alter throw
      Trex 500l Dominator
      Trex 450l Dominator
      Mcpx bl
      Pheonix sim
      dx8
        You set the servo travel adj in ''tramsnitter setup'' section so it gives you 100% travel at ful stick throws shown on the pc software,
        The next thing to set is full cyclic movement without binding in ''swashplate setup section'' this isnt the rotation rate setting you need as much throw here as possible without binding.
        To control rotation rate go into advanced settings click on ''setup 1, 2 or 3'', then click on ''cyclic'' down the left hand side, then at the bottom we see the parameter for ''rotational rate speed'' this adjusts your full rotation rate. The valuse are degrees per second.. for example with a 360 rotation rate the model will flip through 360 degrees in one second!! this is very fast. On my 700n i have it set to 260 i think.
        Hope this helps
        Chris
          Ok will take a look at that cheers chris
          Trex 500l Dominator
          Trex 450l Dominator
          Mcpx bl
          Pheonix sim
          dx8
            You could always use your tx dual rates to slow things down a bit as well. If you want to use your tx expo, don't forget to zero the Gyro's expo per bank otherwise things get a little screwy
              As sesame said, you can adjust it on the page where you center your servos. I simply put my pitch gauge on and set + - 12 on the pitch and a further + - 9 with max cyclic which for me was about 28% on both.
              Trex 500 ESP
              Trex 450 Sport
              Blade SR, mcpx, mSR
              Clearview, Phoenix
              Spektrum DX8
                The Brain is supposed to be set to max cyclic deflection without binding at full positive/negative cyclic/pitch but in reality you need a minimum of 10deg. Anything more is ok but you shouldn't have less. Once done you set your pitch to whatever you feel comfortable with e.g 12deg on my 550. Any changes to roll rates etc will effect the units SL ability as well so bear that in mind.
