Governor sensors
  • Governor sensors
    who has had success with which sensors, ive been trying to get an align one to work but it doesn't want too. anyone else got any suggestions
    All the best
    Tony.
    Revlock has a fut plug only needs 1 magnet, will plug in to brain , or futaba same I believe.
    Align needs to magnets , just cut wire and solder a fut plug on
    Santander Factory Team
    Proud wearer of 5 x EGS
      I used the align did the wire swap but it wont recognise the magnets. maybe the sensor is faulty hmmm. my problem is ive 2 magnets in the fan and taking them out is a real pita
      All the best
      Tony.
        So you have one north and one south pole then, I no Vbar needs swooping with align not sure on brain
          I thought they all only needed one magnet and the other was simply for balance?
          I have Align sensors on 2 helis. One has 2 magnets with opposing poles facing up and the other has a magnet and a brass weight... both work perfectly.
            ON the one im aiming to put it in it has 2 magnets opposing poles. which I have in my vbarred birds and it works as you say fine. this new one was origionally setup for a vbar, and im considering using the Brain from my 600 for it, but ive never got the governor working on it. infact the sensor just doesnt recognise the magnets at all
            All the best
            Tony.
              Well ive got the msh brain and the align sensor, it works great and does pickup on one magnet in the software, make sure u got the magnet close enough, also the wire swap is not needed as the gov in the brain was designed to work straight with the align sensor, if all this fails u hav a fault sensor!!! Good luck
