I know these are fresh out so theres not alot of experience out there yet, but I test flew my Brain on my nitro trex 600 on Saturday. The head seams fine but the tail is very wishy washy and there is alot of bounce on piros. the tail is holding in backward hurricanes but its wandering all over the place and feels very insecure.
The setup of the unit as long as you have played with fbl units before is quite straightforward. and didnt take long at all. although the software is basic it does its job, one think I did notice, once you have set your options in the software, next time you go back into the setup the system doesn't show you the options you made previously, which is a little offputing.
anyway back to the problem, im using a ds8900 on the tail so I have set the software to 1520us and 333mhz which are the figures I got from the net. so firstly can anyone confirm I have these correct. but then any other thoughts?
