Msh brain fitted :)
  • Msh brain fitted :)
    Got the brain fitted tonight on the 450 pro and the dfc head.
    Size wise it's about AR7600 size so just abut fits on the extended AR tray but the pain in the arse is they put the usb port on the opposite end of the servo plugs !!!!
    Setup went ok following the basic program there is no set degrees for cyc unlike Skookum & TotalG (10), beast(6) and vbar's. You have a separate gain for the tail to have a rate & HH, on the bank switching i have it on Aux2 (using a DSX9) with sport and Auto stable, 3D and expert 3D just to start off.
    Hope to give it a fly tomorrow
    Oxy4+, tgy servos, hw60a, spirit fbl on 6s 🤓
    sigpic - Team pilot
    i will need to put on a 450 to check if is good to move on the logo, but my issue is the USB port as you said, is a v2 yours?
    Mikado Logo 600 3D
    Evergreen Raptor 50 now R.I.P.
    Align T-rex 450 V2 gt5 fbl soon controlled by Ardupilot Mega 2.5
    Trex 600 nitro
    Hitec Aurora 9
    PL8 supported by Grant PSU aka "The Black BOX"
      Its a V1 pro that was Fb. The skookum had the right idea as you could mount it across the gyro try
      ohh and the tape sticks like S**t to a blanket !!
      sigpic - Team pilot
        Looking good! Keen to know your thoughts.
        SAB
        Trex 500 FBL /
        Beast X
        Futaba 8FG
        Proud Owner of 2 EGS Awards
          Bit quiet at work so out for a madain, all gyro senses going right go for spoolup bam tail spins and snaps a dfc link off in the holder!! Why! Because of the tail grip flip next time I'll do it on the patio.
          sigpic - Team pilot
            Sounds like your tail gyro was not working the correct way.
            RCHA Member
            LFXproductions.co.uk
              something i remembered when i maidened my 450 pro v1 DFC AR7200BX (flipped grips on tail) yesterday Hard lines mate, at least you know for next time though.
              Looking to purchase one of these for my 700 nitro in the next couple of weeks... interested to here some comments about how it flies compared to other systems. Bery Kammerer seems to love his.
              Lee
              www.raptoruas.co.uk
              www.lee.rcha-uk.com
              www.gensace.de
                Did all the normal stuff, bottom tail blade to the back then left stick blade go's left, HH tail to the right and pinch your finger in the gearbox just forgot about the grips flipped.
                Most annoying is the link snapped off to far in the arm to get it out And to top it off just missed the posty so got to go there after 4pm !!!!
                sigpic - Team pilot
                  Yep, caught me out mate when I first flipped the grips and the heli when shooting like a spinning top into the fence. Annoying!!
                  RCHA Member
                    Fitted my brain to a Logo 400 with YGE60, using RDU sensor.
                    Great setup experience. However, throttle is not playing ball. Ran out of time today :-(
                    How do you calibrate the throttle on the esc with the gov?!
                      There is a YouTube vid on the yge but would have thought it would be the same as vbar?
                      sigpic - Team pilot
                        Hmm I checked it out, I'm having more fundamental issues. Only spools up one time in three, quite slowly but YGE light goes a bit dim I think indicating close to max output. Ah well, can always fly without external gov.
                          Ah, it was just a huge delay. Setting the spoolup ramp to max (10) helped, probably not the right fix though..
                            Got 4 flights in today and it feels nice piro's on the spot no wobbles on tictoc's very even flight on a speed run. Feels better then my beastX ever did would say its like the sk540 , all i have tried is the stock 450 size settings on bank switching sport but didnt use this as i had sl on and it wasnt set. 3D and expert 3D were nice and solid stops very precise. Might let chris have a go on sunday
                            sigpic - Team pilot
                              I heard my ears burning
                              Chris 'CHUNK' Newby
                              ALIGN-TREX.CO.UK team pilot
                              LYNX team pilot
                              SPARTAN team pilot
                              Dx18
