MSH brain and transmitter modes.
  • MSH brain and transmitter modes.
    I normally fly beastx but have just got a mini protos which comes with MSH brain. I am trying to set it up and can go through all the settings on the pc without issue, however the transmitter controls do not align to the actions on the heli. I have followed the diagram with servo 1 going to 1 on the brain etc as per the diagram etc. I am using 2 dsmx sats onto dx9 Tx. What I have worked out is the controls mirror my Tx being mode 1, when in fact it's mode 2. So elevator control seems to be operating throttle and vice versa? I assume I am missing something really simple some where, anyone come across this, got any ideas?
    tx
    dave
    Blade 180cfx , 130x, nano cpx
    Trex 150 dfc
    Trex 450 dfc
    Trex 500 efl pro
    Trex 600e efl Pro
    DJI 450 Quad
    DX8 and DX9
    Sounds like you have got wrong wire in the brain Ports, just go over it again and make sure you have picked the right diagram to follow in software, I've done it a 1000 times, so your not alone.
    Align trex 700x brain 2 BT
    SAB Goblin 700 KSE Brain 2 BT
    Trex 600 ESP brain 2
      Hi, how are you keeping? Your 500 is still flying. :-)
      Help me me spot the obvious mistake. I am following top diagram on PC screen, servo one at the front of the heli goes into servo one on the brain, servo two looking from the back the one on the right goes into servo 2 on the brain, and servo 3 is the one on the left looking from the back going srv3 on brain. Tail is into tail, and esc is into ch1 as per the diagram?
      Apols, photos have come out upside down when uploaded for some reason ?!
      thanks
      dave
      Trex 150 dfc
      Trex 450 dfc
      Trex 500 efl pro
      Trex 600e efl Pro
      DJI 450 Quad
      DX8 and DX9
        Make sure your swash type (in the tx) is set to basic 90 degree one servo, so normal on dx9.
        Menu 5 of setup your stick actions SHOULD match what it shows on screen, you might need to reverse channels in the transmitter so that directions are correct. Presuming you have selected the correct swash type in menu 6, and that your stick actions DO match whats shown in menu 5, you will need to click the servo reverse button on the left hand side of menu 7 until the swash on the heli matches your stick movements, give it a few clicks and move the cyclic stick. You should be able to get everything to match there, if not its possibly wiring
        Dan
        Goblin 700c carbon - Xnova, Brain2
        Goblin 570 - Scorpion, Tribunus, Brain2
        Goblin 420 - Xnova, Brain
        Dx9 black
          Your wiring sounds right dude
          Dan
          Dx9 black
            Yep, when you put the stick movements in on transmitter you get the right movements on the PC, had to reverse channel elevator and rudder, but pitch throttle etc was fine, done travel settings etc, so looks ok on PC, but is not translating to heli, it reacts correctly if I was using a mode 1 transmitter? Have done the servo arm 90 degree setting screen as well, so they are reversed where necessary on that screen as well?
            Trex 150 dfc
            Trex 450 dfc
            Trex 500 efl pro
            Trex 600e efl Pro
            DJI 450 Quad
            DX8 and DX9
              Im not sure where you are going wrong then dude?! Long as the brain swash type is h-3 120 degrees aswel then your setup should be correct... I would say possibly transmitter?
              Check system settings and make sure you havnt selected mode 1 somehow? im not sure you can reassign the channels without switching modes?!
              Have you used the tx before?
              Maybe someone a little wiser has an idea?? Lol
              Dan
              Dx9 black
                Hi, I have been having a similar problem eventually I started from scratch and everything now seems to work in the correct way.
                First I am using a standard Rx setup using JR DMSS Rx, Synergy N5c.
                I completed the setup as you describe with the diagrams using servo 1 etc. However I realised that servo 1 is the elevator and on the JR receiver this is not output to 1 on the Brain so I changed over aileron and elevator, one at a time so that the correct servo moved from the Tx input, then I reversed servos as necessary in the Tx to get all the directions working correctly on the swash. When I completed the setup of the brain all the way through everything worked as expected and crucially also when the Heli is moved the swash moves correctly.
                I must stress that I have yet to complete a flight test!!!
                I hope the above makes sense and may help?
                sigpic thank you.
                  Yep, makes sense. I have set up 3 times now with fresh model on transmitter and rewiring but same result. Checked the transmitter settings and it is still at mode 2. Transmitter still working ok on my other helis that are set up on it, so now at a loss. I have tried different combinations of wires going into brain but with no luck to date, but still a couple of combinations left to go! IF that fails I have a dx8, so I will try setting up on that as well just to eliminate it being a transmitter issue. Happy days!
                  Trex 150 dfc
                  Trex 450 dfc
                  Trex 500 efl pro
                  Trex 600e efl Pro
                  DJI 450 Quad
                  DX8 and DX9
                    Strange one that dude, iv set up brain and dx9 on a couple of helis and honestly not came across anything like that..
                    Where are you bud?
                    Dan
                    Dx9 black
                      Have you verified that all inputs are responding as expected on the transmitter setup page?
                        Yep, all ok on transmitter setup page, does what it should with the odd servo reverse.
                        Based in Gloucestershire.
                        Going to have a go at setting it up on the dx8 next weekend to rule out any tansmitter issues
                        tx all for the ideas so far.
                        Trex 150 dfc
                        Trex 450 dfc
                        Trex 500 efl pro
                        Trex 600e efl Pro
                        DJI 450 Quad
                        DX8 and DX9
