I read somewhere that when spooling up a heli that uses a fbl controller, if you give any, even small cyclic inputs it might bury it's self into the ground before takeoff.
I understand that the fbl unit is effected by ground vibration and that it doesn't function properly until it's in the air, however I'm not sure how or what would cos the heli to tip over before taking off.
I am setting up my Raptor 50 with the brain fbl controller and would be grateful if you would give some advice on this.
Many thanks :-)
Many thanks :-)
