Hi Guys, I was just wondering which channel do I plug the 3pin ESC wire into?
Where Do I plug the ESC - T-Rex 500 dfc
Hi
What flybarless unit is it? And are you using sats or a separate receiver?
Edit I have just seen what category this is under. D'oh!
RichLast edited by Rich23; 04-07-2014, 02:43 PM.SAB Goblin 700C - Black Nitro
Hi yes long time no chat. Hope your well and all is good. Have you managed a flight yet with the 500? And as soon as I asked the questions I realised it was in the Brain forum.Originally posted by z0m8i3 View PostHey Rich, Long time no chat mate
. Its the iKON Brain. (I traded the 3gx in for it)
I think with this unit it has its own setup wizard which you download from the website. Does it not cover the channel assignments in that?
RichSAB Goblin 700C - Black Nitro
Yeah I've had a few flights with it but didn't like the 3GX much as it was too much hassle setting up. In the setup wizard it says to connect the battery(which I'm assuming is the ESC) to channel 2 or 3 but on channel 1 it says throttle which I thought was for the ESC-Battery?Originally posted by Rich23 View PostHi yes long time no chat. Hope your well and all is good. Have you managed a flight yet with the 500? And as soon as I asked the questions I realised it was in the Brain forum.
RichSpektrum DX9
Align T-Rex 500 Pro DFC (WIP)
BLADE MCPX BL
PHOENIX R/C V4
I'm assuming your using the Align 70a ESC still so I would assume you connect the ESC to the throttle channel and use the on board BEC to power the Brain.
Power through throttle - HeliFreak this thread confirms you can use the thro/channel 1 to supply power to the Brain
Just remove the blades and if you can disconnect the pinion from the main gear first.
Hope this helps
Thanks Rich, Yes I'm still using the stock ESC on the 500. I've disconnected the motor from ESC, this should be ok yeah?, just double checking everything just to be sure!Originally posted by Rich23 View PostI'm assuming your using the Align 70a ESC still so I would assume you connect the ESC to the throttle channel and use the on board BEC to power the Brain.
Hope this helps
RichSpektrum DX9
BLADE MCPX BL
PHOENIX R/C V4
