Hi guys
I need help/guidance setting up my Brain for Governor mode in my Trex 550e. I'm running a 600mx (6 poles), Align RCE-BL70G ESC, 11t slant motor pinion, 112t slant main gear and a Hobbywing brushless sensor wired into the motor red/black wires.
1. Do I need to reprogram the ESC? It's set to soft start, no governor. It's a basic Unit and there's not many options to set
2. I've set the sensing divider to 3 according to the instructions (number of poles /2). This seems a little low so can someone confirm this is correct for a 600mx
3. How do I establish the correct throttle min and throttle max settings in the advanced setup menu?
4. What head speeds should I use? Is there a formula to work out the most optimum head speeds I should program the governor for?
Advice welcome
Matt
Advice welcome
Matt
