Vbar Wiring - Futaba R617FS Patch Cables to Futaba R6303SB S-Bus Modification
  • #31
    I am a Smart guy! I Will try today as soon as i came from work!
    • #32
      Originally posted by RcRotaryMadness View Post
      All you need to do is download the required pc software from mikado (you will need to register ownership of the vbar first) you will also need to know what version your vbar is running (5.1 / 5.2 / 5.3) and download the corresponding software.
      Then plug usb into vbar and connect to pc.
      Go through the setup and switch it to futaba sbus. Bind your rx to your tx.. plug sbus into vbar and go from there through the setup menu.
      Matt
      So my vbar is runing the 5.2 software! I have alredy downloaded the 5.3! Do you think i need to cqame back and use the 5.2??
      • #33
        Re: Vbar Wiring - Futaba R617FS Patch Cables to Futaba R6303SB S-Bus Modification
        No, just carry on using the newer software. Just update the firmware of the unit by using online update.
        Julius
        Gaui X3 Fubar
        Trex 500 Vbar
        Trex 550 Vbar
        Compass 6HV BD3SX
        Compass 7HV HC3SX
        Compass Chronos HC3SX
