vbar tail normal mode
  • vbar tail normal mode
    hey guys
    i wanna be able to center my tail servo and set it up mechanicaly in normal mode in vbar, any idea how to do this, havent got all the stuff to finish the heli just yet so cant plug it in yet but just asking in advance..
    thanks
    If you mean rate mode then there is no rate mode,set up as instructed in the vbar software
      You need pro to get it
      Cheers Paul
      Citizen #42
        tis 5.3 pro
          Originally posted by bulnose View Post
          tis 5.3 pro
          Ok
          On tail rotor
          Hit the expert parameters blue icon
          Then you have lock mode(heading hold)
          Rate mode
          You need to be using bank switching
          Cheers Paul
          Citizen #42
            thanks geek, any reason to be using bank switching ? i would like to get a flying model before enabling bank switching to copy to all banks before altering things
              Think geeks saying about bank switching so you can switch between HH and rate mode. Don't see why you need to do this at all (set to rate mode). In the vbar setup with the rudder centred (it does this automatically) just set a couple of degrees to counter torque. Then set the endpoints, if they are vastly different you may need to tweak the centre position. You will need to make sure you have the servo arm as close to 90 as you can get, there is no way to subtrim it to 90.
              Mikes Place - Home of the golden dump.
              Sponsored by Elite Models.
              http://www.elitemodelsonline.co.uk/
                ahh thanks swashb, so while in the setup procedure it centers the servo so even if i move the heli while doing linkages and fitting the horn on the spline it stays centered
                  Correct
                    Yes
                    I use it for walking to the flight line.
                    Then as I spool up I switch to HH using bank switching
                    Cheers Paul
                    Citizen #42
