Help with cyclic throw on mini vbar
  • Help with cyclic throw on mini vbar
    I'm trying to adjust the cyclic throw on my 500 with mini vbar and I'm not really understanding how to do it? can anyone give me a few pointers, thanks
    Trex 500l Dominator
    Trex 450l Dominator
    Mcpx bl
    Pheonix sim
    dx8
    You don't really adjust the cyclic throw.. you set it to 8 degrees over the boom as per the vbar setup then just increase the agility sliders on the main page to increase the cyclic rate.
    Matt
    Goblin 500 Sport
    Owner of
    One E.G.S.
      If you need to limit the travel of the servos then theres a swash ring setting on the pro software under one of the tabs if you need stop any binding.
      Matt
      Goblin 500 Sport
      Owner of
      One E.G.S.
        Another way to do it is set the agility slider to 100% and set your cyclic to your liking. Ie set say 9 or 10 degrees or whatever gives you the flip and roll rate that suits you
          Thanks matt sorted it with swash ring setting cheers for the help
          Trex 500l Dominator
          Trex 450l Dominator
          Mcpx bl
          Pheonix sim
          dx8
            Thats a new one on me Dave! Thought the vbar had to be set to 8' nothing else?
            Avant mostro 700E
            Avant mostro 700 Nitro
            member of :
            South cheshire heliaddicts
              I'm guessing if you set it up that way then you would have to leave the slider on 100% and do the setup thing if you wanted to adjust it?
              Matt
              Goblin 500 Sport
              Owner of
              One E.G.S.
                No, the thinking is that the control loops are optimum at 100%, and that it's better to adjust the cyclic rate. If I'm not mistaken Andy K max's out the cyclic pitch. Not totally sure of the science behind it and I wouldn't say I could feel any difference but most of the big boys do it, the same as the optimiser values are punched in rather than run an optimising fligth. Nick Maxwell, Kyle Dahl ETC all do it, there are some values on the likes of HF for the e700 not sure about other helis.
                Even Duncan does it like this.
                  Yes, but I think you would only need to do it once or twice before you got to the value of cyclic that worked for you
                    It's a common thing on lower head speed machines to up the cyclic value from the 8 degrees. It can provide more bite when you get that soggy feel to your heli.
                    Invertix 400
                    Vortex 285
                    TBS Discovery Endurance
                    X4 II
                    Schluter Champion Longranger
                    G4 E720
                    G4 E720 Big AIR edition
                    Goblin Urukay super slow
                    Goblin 700 KSE Slow
                    Goblin 700 KSE Fast
                    Srimok Faifa
                    Spectra G
                    Synergy 766
                    http://mangled-rc.com/
                      Hi I set my trex 500 with a mini vbar I had a problem with the cyclic throw when setting up set it to 8 degrees but when out of set up mode had about 12 degrees which caused the elevator servo to bind apparently this is normal when on the bench but when in the air it wont do it there is some posts on the vsabi forum about this , well my 500 flys ok so all good.
                        well I flew it this aft and all seems good, thanks chaps
                        Trex 500l Dominator
                        Trex 450l Dominator
                        Mcpx bl
                        Pheonix sim
                        dx8
