Minivbar electric gov
  • Minivbar electric gov
    I have an Hyperion phase sensor and want to setup the gov
    Can I use port RxA for the sensor or do I need to use a y lead on either Rxb or Rxc
    Step 2: Enabling the governor | VStabi
    Santander Factory Team
    Proud wearer of 5 x EGS
      VBar 5.2 - Episode 19 - Phase sensor on Mini - YouTube
        RXA top pin.
        MJ
          Exactly what I was looking for thanks chaps Click image for larger version
            Exactly what I was looking for thanks chaps [ATTACH]70709[/ATTACH]
            that setup a little underpowered for your tsa 700 lol
              Don't ever change Bri lol
                Don't forget you must not apply any power to any of the pins on RXA - They're all I/O's to the processor. IIRC Signal voltage from the sensor must not exceed 5v.
                Matt
                Goblin 500 Sport
                Owner of
                One E.G.S.
                  Top pin for signal I used to take power for the sensor from the sat port.
                  MJ
                    I had the Hyperion phase sensor on my 550sx ,am I muddled up but don't you need the hobbywing phase sensor as you are running high voltage or are you running 6v only ?
                      Don, What ESC are you using? If its a castle and you're running the latest firmware on it, then only the hobbywing phase sensor will work. The Hyperion is an Analogue sensor whereas the Hobbywing sensor is digital. The newer castle firmware outputs to the motor in such as way the analogue hyperion sensor can't read it correctly.
                      Edit: Also with the digital sensor you don't need to ground any separate RX packs either.. if your using one that is, if its a BEC then it doesn't matter anyway.
                      Matt
                      Goblin 500 Sport
                      Owner of
                      One E.G.S.
                        No matt I'm running a turnigy helidrive( YGE/YEP copy )
                          Ah right, i have no clue about that esc but should you have any weird rpm readings in the vbar software (think mine was reading 3 times higher than expected with the analogue sensor) then try the other sensor (assuming settings in the vbar are correct etc.
                          Just something to keep in mind should you experience problems :-)
                          Sent using the wireless magic of my Galaxy SII via crapatalk.
                          Matt
                          Goblin 500 Sport
                          Owner of
                          One E.G.S.
                            George ran that combo with Hyperion sensor no issues at all. Wire as previously discussed and go fly.
                            MJ
