The problem with the mini vbar is that it doesn't have enough channels for running nitro etc. so would need to be redesigned a little. But apart from that I've never had any problems with the blue line. It does however make it more difficult to run a separate sensor making your wiring options difficult at times.
I use a mini on my 700n Rob, a slight change to the config and you've got your governor gain.
Take a bit of credit for the discount myself cos I contacted fastlads to see if the would match mikado, the next day it was discounted, not got one yet but certainly will do before the weekend. Cheers FastLads
