anyone got their pre-order cgy750 got call today to say it was in shouldo get it tuesday!! cant wait to try it!
cgy750
Yep. Picked two up from Fast Lads this afternoon!!! Will be fitting them next week and hopefully be test flying them next weekend.
I got the 8 channel SB receivers as the 3 channel are in short supply but FL did the 8 channel ones for me at no extra charge!!! Thanks FL!!!
The 8 channel receivers are quite small and neat. Can't wait to test fly them.
I think you'll find that any of the SB receivers will work fine and the 3 channel one is not specifically "made for the 750". I went for the 8 channel as channels 1-8 can be programmed to be 9-16 via the receiver. I run SwitchGlos so they can be assigned to a high number channel instead of channel 1,2 or 3 and then re-asigning the channel used. I also thought that it can be used as a normal receiver if I need to. The 8 channel one also has the HS function on channels 1-6.
Very jealous!Harry
Powered by Futaba 18SZ
Really interested to hear flight reports especially from Flybarless experienced pilots and how it compares to BeastX and Vbar.Last edited by Sticky Stick; 31-03-2011, 09:20 PM.
I'm gonna have to wait for the spekky adapter to come out b4 I can even think out getting one LOLKel Velocity 50 sk-720 ,Fusion 50 v-bar pro 5.2 ,Velocity 90 v-bar pro 5.2
& JR DSX11 ,Phoenix and a fridge full of bottled water
RCHA Courier Services PM for Details
www.parcelshipper.co.uk and www.impactexpress.co.uk
