CGY750 - What TX throttle curves?
  • CGY750 - What TX throttle curves?
    What sort of throttle curves should I be setting up in the Transmitter?
    This is an electric heli using the onboard governor.
    Straight lines or V curves?
    Just need to clarify this before I mess about any more trying to set the unit up.
    Blade mCPX - now Version 2
    A shallow v-curve is recommended, I run a straight as normal and have noticed no difference
      What sort of values on the V curves?
        Am I missing the point?
        It's a governor, so it governs the headpeed, just like a gyro governs the tail position. You, the pilot are not in control of the headspeed or the tail, the electronics are. The electronics just respond to a rate of change input (i.e. how far you push the sticks).
        So, why even think about this question?
        Just set the gear ratio and headspeed to the required value on the CGY750and go fly. Your Tx isn't required to maintain headspeed.
        JR Vibe Fifty fb (YS56)
          Wish it would work as a governor that would be great!
          Going through every possibility with this as I still can not get it to work properly.
          Pretty sure it's a setting somewhere but don't know what at the moment.
