Horizontal stabilisation question
  • Horizontal stabilisation question
    Hi guys just wondering if the stabilisation facility will work when inverted ? It's all set up working fine including the rescue feature but I'm just starting to hold inverted for about 30 seconds before I start losing my orientation and flip it back round to keep control my query is if I could use the stabilisation feature while inverted so I can learn my orientation. if I flip the switch while inverted it will flip round and hold steady hover, wondering if it's even a possible ?
    .Goblin 630....Goblin 500...450L dominator...Assault 700...300 CFX...Trex 450 v2 flybar ..Trex 150 ...Blade Mcpx
    ...BD3SX.........HC3SX.............Spirit......... ..AR7200BX......VX1N........Spartan Quark.....................................
    I think the feature will flip you right side up and add collective
      It is an option you define. You can have it remain whichever way up is nearest or always return right way up. You can swing on the right stick whilst in recovery mode and it will still whip over for you too.
      Just a trusty rusty Raptor E550 these days
        Will check the settings although its not the recovery mode I was asking about, that's all setup and working it will add collective pos/neg depending on what the heli is doing when I flip the switch.
        i was asking about the horizon feature which make it behave like a coax heli almost when you let go of cyclic it levels out without any collective being added was wondering if that also worked the same while inverted as at the moment while inverted if I let go of cyclic it will flip the heli over and hold it level.
          Yes it will work just the same as recovery, but without climbing if set right.
