Hsc3x
  • Hsc3x
    Hello all,
    setting up an Hc3sx for a mate and got it all flying great including captain rescue. The problem I have are forward and backward flips are great but the aileron rolls are very slow, which setting do I increase to speed them up?
    Many Thanks
    Kev
    Hi Kev,
    In the RIGID tab you can either increase the aileron gain though I can't imagine why this would be any different from elevator (maybe depends on swash type) or increase agility. Make sure the flybar setting is correct.
    If you assign these parameters to an easily adjustable channel (knob) on the radio via the REAL TIME TUNING tab you can adjust in flight to exactly the right setting. Then write the value from the real time tuning section as a permanent value in the RIGID tab.
    Thunder Tiger Raptor E820 - KDE 700XF 395 - YEP 180A - Futaba HV 272/274SV - Bavarian Demon 3SX - SAB 800mm - 6.6V LiFE
    Blade 450X - Stock AR7200 Beast X
    DX8 - AR8000 + Sat & TM1000 Telemetry
      Hey Kev, sorry to be nosey mate, but what radio did you set the HC3sx up on?
      cheers, Dave.
        Set up on a DX8, think I have the answer aswell. when I set it up I reduced the servo travel to stop binding of the swash which then limited the overall movement
