helicommand hc3sx and the JR dsx11
  • helicommand hc3sx and the JR dsx11
    Hi All
    Has any one managed to setup the HC3sx with a JR DSX11 using a spectrum 8 channel receiver.
    When i try to set up the system the page that you use to allocate the channels comes up and then goes immediately.
    I need one of the channels for the gryphon auto boost and was also going to try and use an align governor.
    I can't fly very well that is why i wanted the bailout option.
    I have managed to setup the tail and head gains to the rotary wheels at the back of the transmitter
    But i would have to fly with out the bail up option so i can set up the head gains, can these not be done in the software prior to flying.
    I don't even fly in idle up so would the rescue still work i use a pitch curve to set the blades angle of attack
    I have moved on a Vbar for this unit not sure if it was a wise choice
    You should have 3 spare channels to play with as you can also steal channel 5 if you don't want to adjust tail gain from the tx.
    Have you updated your pc and fbl to the latest versions?
    Just a trusty rusty Raptor E550 these days
