Just curious; gpro quality?
  • Just curious; gpro quality?
    A guy at my local club was having a few problems with his heli setup and as soon as I saw he was using the Align FBL unit I figured it was the problem. But now I think it was a worn servo that may have been causing the problem. I've tried a few FBL units and found some better and some worse, ease of setup is usually the biggest differentiator but the 3GX was a non-starter utter rubbish. So my question is; is the GPro that much better? Why?
    ps. I'm all vbar now and not thinking of changing. I'm just curious about whether Align still deserve the bad rep that they have for their FBL units.
    i havent heard much bad stuff about the gpro.
    but then again i use the 3gx on one of mine with no problems at all..
    Spektrum IX12
    Blade Inductrix
    T-Rex 150X
    T-Rex 450L, Heli Option Turn-buckles, carbon push rod, 6s, Stock Electrics, Giant Power Lipos
    Goblin 380 Kyle Stacy, 360mm, 6s, AR7210BX, Align 430m/525m @ 6.0v, Castle Talon 90, Scorpion 3020-1000, Optipower 2700 30c
    Goblin 570 Carbon Red, Stretched to 600mm, Blackline 3D Blades, 12s, BD 3SX, Align 800/850 HV servos @ 8.0v Castle 120 Phoenix Edge HV, Scorpion, Thunderpower G8s
    T-Rex 800e Pro DFC, Hobbywing 200A, 760x Head, BeastX
      I binned the align 3gx and moved over to the beastx
        No problems here. GPRO works fine for me.
        Graham
        Titan X50E Bavarian Demon 3SX
        Trex 500L Bavarian Demon 3SX
        Trex 450SE Flybar
        Futaba 14SG
          Heres someone checking the ruggedness of the unit following some issues, just ask ChrisB
            Hey buddy.
            As someone who spent ages with the original 3G, then 3GX and a Gpro I can say with complete honesty the Gpro is deserving of a try by anyone. It does need some refinement, Align have left it hanging a little in favour of quads at present which is annoying, but setup and flying wise the Gpro is a good candidate.
            If Align come back to it and work out the slight kinks in an otherwise good little package, it will be even better.
            I found out very early one of its major issues and that is that it's a power hungry FBL unit, not many could see this but it soon became apparent when they were pointed in the right direction.
            It's not necessarily a problem as long as your power system is up to the job and the Gpro is not alone with a higher than desired power requirement, other FBL units are the same to.
            As Align spend time refining the current package this issue will fix itself.
            I would say if you have one don't be worried about trying it, you may be pleasantly surprised at its performance.
            Ian Contessa
            Coolice Power Supplies
              5 of my heli's are Gpro admittedly i had tail problems in the earlier days of setting up but now anyone's welcome to see how they perform in flight.
              • Flickr Through My Pictures.
                That is ridiculous. What is the point of doing that?
                Graham
                Trex 450SE Flybar
                Futaba 14SG
                  Programming PEBKAC?
                  Thunder Tiger Raptor E820 - KDE 700XF 395 - YEP 180A - Futaba HV 272/274SV - Bavarian Demon 3SX - SAB 800mm - 6.6V LiFE
                  Blade 450X - Stock AR7200 Beast X
                  DX8 - AR8000 + Sat & TM1000 Telemetry
                    I think Chris had so many issues that he moved on, not sure if it was him that totalled it but take a look at his posts on it and you might get why
                      Our clubs chief Align hater did the honours,i was going to just bin it,it was the second one i got that was junk,this one was purchased (new) second hand from someone who removed it from a kit,i had no warranty help from Robbe as i didnt buy it new myself,one was just dead and on this one none of the gyros worked when you moved the model no response on cyclic or tail.
                        It's a bit worrying to think that these controllers could have issues with being dead on delivery. I have never had a problem with Gpro but it would be a concern if they are badly assembled to the point that it's pot luck whether you get a good one or not. That would indicate that they have the potential for an in-flight failure.
                        I do know that the one thing that will kill them dead every time is connecting the power supply incorrectly, but beyond that, they should not have problems. At £125 for a new one, they are not a mickey mouse unit. Not too sure whether this is a confidence knocker or not.
                        Graham
                        Trex 450SE Flybar
                        Futaba 14SG
                          Ive got 5 & everyone of them were dead until i done the bind & then work fine.
                            Have gpro on all 4 of my helis, can't fault them, ease of setup won it for me, and the fact you can get them around the £60 mark is a plus
                              Just set up my first Gpro yesterday and was amazed how easy it was. I fly Futaba and used the Sbus connection to reduce the number of connections going to the receiver...So far so good as they say.
                              Align Trex 550L Dominator X2
                              Align Trex 500L Dominator
                              Guided By
                              Member of the Blyth Valley RMC
