Gpro Throuble Shooting.
  • Gpro Throuble Shooting.
    As title place it here:
    If using A Tablet Bluetooth to save setup/parameters it seems you will need to log out & log back into save your setup/parameters changes.
    • Flickr Through My Pictures.
    Can you test fly with bluetooth module connected or best to unplug each time.
      If setting up 250dfc you will need to use the 40mm tail blades with default Gpro settings.
        I have been leaving mine connected,just tap disconnect on tablet before flying again.
        I was exploring effects of subtle changes so just flew,landed and hit connect on tablet,did the change then disconnect.
          Ar good ill do the same, Ive noticed the button on the Bluetooth module does the same.
            My 600e pro is setup as per Gpro pc setup throttle 100% 0% 100% but now I'm setup wrong for the cc hv 80 throttle setup as I now have no spool up, so i reset up throttle with ESC & checked Gpro PC software I'm now out of the Gpro throttle range, any ideas...?
            The heli now spools up but not sure if ok to fly it.
              Because I'm running separate bec with yellow wire diconnecred I dont think it matters about the Gpro throttle 100% end point setup, so you just go ahead and setup your cc hv80 throttle end points, she's flying very nice now.
                I've now setup Gpro on my 250, 450, 500, 600 only issue was tail on all 4.
                So my advise is go through the pc/bluetooth setup & in tail setup do a mechanical setup of the tail, manual for Gpro or heli Manual are not that clear, my advise is to center ether tail slider or tail blades on the linkage rod & not in the software setup, then hover heli & if your getting any drift adjust the linkage rod to compensate then go back into your setup & adjust tail slider end points, once done go into parameters page lower gain to 60%.
                Other than the above only other thing needed to do was to slow left/right rudder stops so they equal your flying style.
                This bit of kit makes the heli so stable all 4 heli's i can take off with nose-in with no drift.
                  Trying to pair my phone with the gpo Bluetooth module & as I touch the gpro app on my phone to pair the gpro module flashes faster to show connecting but doesn't make the paired connection my phones on android 4.2.2 any ideas...?
                    just ordered a Gpro for my 600, been looking at the software, on the setup on the left hand side it say have your swash set to H1, but later on its askes you to pick your swash, which would be HR-3
                    so do i keep radio set to H-1 or HR-3
                      Radio should be set at non ccpm , hr1 the swash set up is done in the Gpro .
                        Here is the video I watched to learn about how to setup the GPro:
                        https://www.youtube.com/watch?v=M7gkMbbrVQA
                        Really easy, and If you have use a vbar this will be near enough the same to setup.
                        Jr forza 700 - one mean machine!lol
                        Logo 600sx v2- the big boy
                        Trex 550l- crazyness
                        Optim 80cp- Just amazing!
                          Also at any point of the setup you can opt out & when your ready you can continue from where you left off by going onto 'Edit Current Settings'
                            H-1 in radio, the segment later on is asking you which layout your servos are in, so centre servo front/rear etc.
                            www.accurc.com
                            adrian@accurc.com
                            This is an apple free zone
                              Cheers for that guys will have a go at it tomoz
