Fl760 into a t rex 250
  • Fl760 into a t rex 250
    I'm looking to fit one into my 250, would you recommend using metal plate or just good quality gyro pads? Also can I mount both the main unit and the gyro upside down?
    proud owner of 1 EGS sigpic
    I've just put one in a 450 SE v2
    And had to put the sensor on the bottom plate because it was picking up bad vibes from the tailboom mount
    DX8
    Phoenix
    RealFlight 7
    Mcpx BL
    Trex 550 DFC with Vx1n
    Trex 700 DFC Pro Hv with Vx1n
    Zmr250 mini H Quad racer
      Hey.
      Id just use a foam pad and both units can be mounted upside down. Going through the DIR setup mode teaches the FBL unit what orientation it's in with regard to control corrections.
      Ian Contessa
      Coolice Power Supplies
