3G 2.1 tail issues Coolice Help!!
    Yes HH is working, the led goes green above 50% only had a quick hover in the garden but im happy the thing stays pointing where i put it
    Just need to eliminate the bounce caused by sharp rudder inputs
    Throttle curves i use flat 80% on idle up
    DX8
    Phoenix
    RealFlight 7
    Mcpx BL
    Trex 550 DFC with Vx1n
    Trex 700 DFC Pro Hv with Vx1n
    Zmr250 mini H Quad racer
      What TX you using
      • Flickr Through My Pictures.
        Originally posted by tourerjim View Post
        What TX you using
        I'm using a DX6i
        DX8
        Phoenix
        RealFlight 7
        Mcpx BL
          First just check the tail move tail stick so tail slider relaxes to one side then flick gear switch to rate mode & tail slider should centre.
            Yeah that works
            DX8
            Phoenix
            RealFlight 7
            Mcpx BL
              Ok, next drop the gyro gain down to 50% in HH then fly her again.
              pm me when you tried it tomorrow.
                Hey.
                Remember 50% heading hold gain will be 75% travel in the tx ATV page, as anything below 50% ATV as you've seen changes the gyro to rate mode.
                Now you're in HH mode the tail cill be so much more held through manouvers, the bounce can be improved further by lowering the lock gain further and/or increasing the delay slightly. You can do this more accurately while its connected to the pc showing the live values.
                What model setting have you set in the delay options, large or small heli delay?
                Also what length arm are you running on the tail servo? As running a shorter arm can help with this problem and allow a higher gyro gain by reducing the mechanical gain.
                Ian Contessa
                Coolice Power Supplies
                  Right, Just tried 75% on the tx, a bit of wag in a hover and sharp wag after a turn
                  70% on the tx, it holds great and only bounces twice after a sharp rudder input, This is with lock gain at 50 and delay at about 60
                  I think the servo arm is 10mm from centre to ball centre
                  P.s its set as small model in the program
                  DX8
                  Phoenix
                  RealFlight 7
                  Mcpx BL
                    Hey.
                    You could lower the lock gain a bit more, but I'd look into fitting a shorter servo arm, 10mm's quite large on a 450 which is my personal feeling. I'd try putting the ball 8mm out and resetting the tail gyro settings before flying again.
                    The benefit to this will be a reduction in mechanical tail gain, which would allow you to raise overall gain and this would help the lock gain to not be so high due to the mechanical advantage.
                    Ian Contessa
                    • #25
                      Just had another quick go after turning the lock gain down to 35, again better but there is still a hint of bounce there
                      I need to get hold of another servo arm as i've only got the 10mm one
                      DX8
                      Phoenix
                      RealFlight 7
                      Mcpx BL
                      • #26
                        Also i'm leaving the Y cable plugged in for the time being until i'm happy with the setup, this won't be a problem will it?
                        DX8
                        Phoenix
                        RealFlight 7
                        Mcpx BL
                        • #27
                          Hey.
                          No, won't be a problem at all. All my machines with 3G had a Y cable left in place, saved having to keep pulling the plugs out and risking loosing a good connection. On my 450 I actually modified one to make it shorter to suit the smaller model better.
                          Ian Contessa
                          • #28
                            Agree with coolice to move the link in on servo horn but I'm also wondering if your esc is setup with gov.? as this will defo cause it, your esc should bleep 1, 2, 1, 2, 3, 2
                            • #29
                              No I'm not using the gov as I heard the align esc's gov isn't too great
                              DX8
                              Phoenix
                              RealFlight 7
                              Mcpx BL
                              • #30
                                How have you got on have you moved the tail servo link in"
