600le 3g v3.0 setup
  • 600le 3g v3.0 setup
    hi i'm new to flybarless does anyone recommend a good setup or do i just fly the standard setup and start from there? Oh and if your adjusting at the field do you fly with the Y lead attached because i dont like the thought of plugging it in and out each flight.
    Trex 700e dfc vbar'd
    Trex 450 dominator vbar'd
    dx18
    Here you go Richard:- Bert Kammerer R/C Helis
      Forgot to mention this one too:- 3G flybarless - some thoughts on setup
        cheers JZ
        dx18
          Search for member 'coolice' and see his posts, he is the '3g' guru.
          I fly with the 'y' lead permanently attached. Had too many problems with poor connections before, cost me 2 crashes.
          TRex 500 FBL DFC VBar Pro Blueline, Standard Align Setup.
          TRex 500 Pro DFC 3GX, Standard Align Setup
          mCPX
          Phoenix
          Futaba 10C
            Hey.
            I have some good 3G settings for writing to the 3G once you have done the DIR setup steps.
            As above, on all my models I fit and leave in place a Y lead. As like yourself I didn't think constant disconnecting was a good idea.
            If you want my honest opinion go to V2.1 firmware and not V3. While V3 improves the tail I was not happy with the cyclic feel and could not get my models flying as well on V3 as I did with 2.1 so I am now running 2.1 again.
            Ian Contessa
            Coolice Power Supplies
              thanks coolice i have gone back to the v2.1 done DIR and i'm trying your setups next time out and see how it goes, thanks
              dx18
                can anyone tell me what some of the slider movements achieve? i.e i understand bell hiller mixing what flying defferences will i gain from moving the sliders
                dx18
                  Hey.
                  Align do give you some half decent explanations of what each slider does, from here in my case I knew what I was trying to eradicate in how the model felt then moved the sliders which corrisponded best to what I wanted to fix.
                  Unfortunately this type of messing about is not for everyone, I've been in the hobby for a lot of years and so have come to understand what certain changes make to a models feel.
                  Ian Contessa
                    right i cant work out what i need to do, when i'm doing back flips i get ocillation i cant decide if its from the tail or what, rolls, tic tocs etc no problem. can anyone give me any idea's as to what i need to adjust? other than that i'm lovin it. i'm thinkin i need to drop the aileron lock gain
                    dx18
                      Hey.
                      Try writing my 550E settings to your 3G and see if it helps.
                      HeliFreak - View Single Post - Coolice's 3G Model Settings Files For Align PC Software
                      Ian Contessa
                        Hi coolice. crustysphinkter and I both have Leon Luke's settings and they are the dogs doodahs. Flips in about 2 millseconds and rolls in about 1 millisecond (only joking). YOUR settings are very GOOD too. We are just learning with the FBL and I am just learning PERIOD. Such a great learning curve. It certainly gets the blood churning.
